Component: IntOsc Helper (Matrix Tools)
| Author | MatrixTSL |
| Category | Matrix Tools |
IntOsc Helper component
A component to help configure the speed of the internal oscillator. Currently only supports 8-bit PIC devices.
Please click here to download the component source project: FC_Comp_Source_IntOsc_Helper.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_IntOsc_Helper.fcfx
The INT OSC helper component is designed to help you configure the rate of the internal oscillator on-board your microcontroller.
It can be found under the Runtime -> Matrix Tools component category.
The oscillator speed drop down menu shows you what speeds are available on your device. Use this to select a speed.
Once you have chosen your required internal oscillator speed copy the code from the Code property.
Paste the configuration code into a C icon at the top of your main macro.
Next change the clock speed in the project options to match your oscillator speed. This will ensure that delays and baud rates are calculated correctly.
If the clock speed is not available as a dropdown value, then you can manually enter the speed value.
Finally, you need to enable the internal oscillator in the configuration settings.
If everything is correct then the Info field should confirm that the project options clock speed matches the current speed selection.
|   | Initialise |
| Called to set the internal oscillator speed to the specified value. | |
|  - VOID | Return |
