| Author
Matrix Ltd.
| Version
1.2
| Category
Misc
Component Labels component
Automatically generates labels for all panel objects and components in a given context. Labels will always face the camera, and can show the name of each object, or any chosen property. Nesting can be used so that components within components are labelled, and so on.
Please click here to download the component source project: FC_Comp_Source_auto_labels.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_auto_labels.fcfx
Hide
Hide
| Hides all labels.
SetColor
SetColor
| Sets the color of the labels. Note that this affects all nesting levels, so any nesting level specific colors set in the properties panel will be overridden.
- ULONG
Color
| Color to set the labels to.
SetTarget
SetTarget
| Set the target object. All items within the scope of this object will be given labels, not the taget object itself. If the target is set to zero or 'this', all objects in the current scope will be labelled.
- HANDLE
target
ShowNames
ShowNames
| Sets the labels to show the names of objects.
ShowProperty
ShowProperty
| Sets the labels to show a named property of each object.
- STRING
Property
| Name of the property to show.
Update
Update
| Refresh the labels after a change.
Show
| Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Auto Update
| Automatically update the labels whenever panel items are added, deleted or re-named.
Auto Target
| When auto target is on, the auto labeller will label every item in its own context. When off, the "SetTarget" macro must be used to set the scope of the labeller.
Color
| Color of the labels text.
Background
| Color for label backgroiunds - may be transparent.
Always On Top
| Whether labels should always be draw on top of other objects.
Size
Scale
| Sets the basic size (text height) of the labels.
Follow Zoom
| Whether labels get bigger and smaller when the panel is zoomed in and out.
Offset
Auto
| Attempt to automatically move the label to the side of the object. Choose a positive or negative offset in any of the three axes. When 'off' is chosen, you will be able to enter manual offsets along each axis.
Nesting
Nesting
| Whether to label child items of groups, groups within groups etc. Off - only items at the same level as the labeller get labelled. Nest levels - how many 'generations' to iterate into groups. Show Leaves - does not label groups, but labels all individual items, no matter how far nested.
