Component: Magnetometer 3-Axis (HMC5883L) (Movement Orientation)
(Redirected from Component: ID 4c2256c0 4453 4369 8c36 09770d223a09)
| Version | 1.6 |
| Category | Movement Orientation |
Magnetometer 3-Axis (HMC5883L) component
HMC5883L 3-Axis Magnetometer sensor Useful for working out data such as compass orientation.
Version information
Library Version, Component Version, Date, Author, Info 8, 1.0, 03-09-24, BR, Fixed compile error on ESP for potential missing return variable
Here is a very simple demonstration on how to use the sensor to read X, Y, Z magnetometer data from the sensor.
CollectXYZData
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
Read_Bearing
Read_Register
| Read_Register | |
| Reads a value from a register on the accelerometer. | |
| Reg | |
SimSetCompass
| SimSetCompass | |
| Allows the XYZ slider values to be set via the simulation | |
| X | |
| Y | |
| Z | |
UpdateCompassData
| UpdateCompassData | |
| Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
Write_Register
| Write_Register | |
| Writes a data value to a specific register on the accelerometer | |
| Reg | |
| Data | |
Please click here to download the component source project: FC_Comp_Source_Magnetometer_HMC5883.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_HMC5883.fcfx
