| Author
Matrix TSL
| Version
0.1
| Category
Graphical Monochrome
GLCD (SSD1306) SPI component
Graphical display component based on the SPI version of the SSD1306 monochrome graphical controller IC. Functions without the use of a read pin forcing the data to be written a byte at a time.
FREE
The following files provide examples of how to use this component:
Digilent - Basic IO Shield
- This template allows users to quickly and simply get up and running with their hardware.
- The default microcontroller for this template board is the 32bit PIC32MX320F128H found
- on the Uno32 hardware.
- It features;
- 4x push-switch, 4x slide switch
- 8x LEDS, 1x Potentiometer
- 1x OLED Screen
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SendCommand
- BYTE
Command
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
ControlDisplay
| Allows the display to be switched on and off
- BYTE
Control
| 0=Off, 1=On
SendData
- BYTE
Byte
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ControlContrast
| Sets the display contrast from 0 to 255.
- BYTE
Contrast
| Range 0 - 255, Default 207
Uninitialise
ClearDisplay
SetBackgroundColour
| Specifies the colour of the foreground
- BYTE
PixelColour
| 0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
| Specifies the colour of the foreground.
- BYTE
PixelColour
| 0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Pixel Width
Pixel Height
Interlaced
| Determines if the display is interlaced in the Y axis or not
Monochrome
Foreground Color
Background Color
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Data (SDA)
| LED backlight strobe pin connection
Serial Clock (SCL)
| Reset pin connection
DataCommand Pin (DC)
| Data / Command select pin
VBAT Enable
VDD Enable
| VDD Enable Pin
Reset
| The LCD Reset pin
Simulations
