Component: Type Conversions (Calculation)
Category Calculation
Type Conversions component
Component to simplify the task of converting data into different bit type variables. Allows conversion between Bytes, Ints, Longs and Floats. Useful when you need to store Ints, Longs and Floats into Byte based memory. Uses a simple 32-bit C Union to overlay the following variable types into the same RAM space. Byte[4], Int[2], Long, Float
The type conversion component overlays several variable types on top of each other using a C code union.
This allows for very efficient conversion between data types without resorting to costly mathematics or bit shifting operations.
Here is an overview of the variable overlay.
Type Conversion Overlay Map
this example converts several different variable types.
TypeConversions Example
GetByte
GetByte
Gets a single 8-bit BYTE value. Index is in little endian, 0 is the LSB and 3 is the MSB
- BYTE Index
Range: 0-3
GetFloat
GetFloat
Gets a single 32-bit FLOAT value
- FLOAT Return
GetInt
GetInt
Gets a single 16-bit INT value Index is in little endian, 0 is the LSW and 1 is the MSW
- BYTE Index
Range: 0-1
GetLong
GetLong
Gets a single 32-bit LONG value
- ULONG Return
SetByte
SetByte
Sets a single 8-bit BYTE value Index is in little endian, 0 is the LSB and 3 is the MSB
- BYTE Index
Range: 0-3
- BYTE Value
Range: 0-255
SetBytes
SetBytes
Allows all bytes to be set using a single macro
- BYTE Byte0
- BYTE Byte1
- BYTE Byte2
- BYTE Byte3
SetFloat
SetFloat
Sets a single 32-bit FLOAT value
- FLOAT Value
Range: 0-4294967295
SetInt
SetInt
Sets a single 16-bit INT value. Index is in little endian, 0 is the LSW and 1 is the MSW
- BYTE Index
Range: 0-1
- UINT Value
Range: 0-65535
SetLong
SetLong
Sets a single 32-bit LONG value
- ULONG Value
Range: 0-4294967295
Generate Code
Please click here to download the component source project: FC_Comp_Source_TypeConversions.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TypeConversions.fcfx
