Component: WLAN (E-Blocks 3) (Comms: Networking)
(Redirected from Component: ID 73973401 ddc0 46a9 ba3b baf5e877ce07)
| Author | Matrix Ltd. |
| Version | 2.4 |
| Category | Comms: Networking |
WLAN (E-Blocks 3) component
Wireless LAN component designed to work with the E-blocks 3 CapTouch display module. Requires the GLCD (E-BLOCKS 3) component to be present in the project.
AcceptClose
| AcceptClose | |
| Close the socket associated with the Accepted incoming connection | |
AcceptOpen
| AcceptOpen | |
| Returns 1 if there is an incoming connection on the listening port | |
ConnectToSSID
CreateAccessPoint
Disconnect
| Disconnect | |
| Attempts to disconnect from the SSID. | |
| Initialise the WiFi system Returns 1 if successful Returns 0 if not | |
ReadEncryptionModeFromScan
ReadIP
ReadIPString
| ReadIPString | |
| Collects the local IP address and returns it as an ASCII string. e.g. "192.168.0.1" | |
ReadSSIDFromScan
| ReadSSIDFromScan | |
| Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first. | |
| Index | |
| SSID Index | |
ReadSignalStrengthFromScan
ScanForSSID
SocketClose
| SocketClose | |
SocketConnect
| SocketConnect | |
| Address | |
| Port | |
SocketListen
| SocketListen | |
| Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail | |
| Port | |
SocketOpen
| SocketOpen | |
| Returns 1 if socket sucessfully opened | |
SocketRead
| SocketRead | |
| Buffer | |
| Size | |
SocketWrite
| SocketWrite | |
| Buffer | |
| Size | |
Uninitialise
| Uninitialise | |
| Shuts down the WiFi system for low power operation. Returns 1 if successful Returns 0 if not | |
Please click here to download the component source project: FC_Comp_Source_WLAN_EB3_CapTouch.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_EB3_CapTouch.fcfx
