Component: Colour Sensor (EBM018) (EBM Modules)
(Redirected from Component: ID 749afd05 ce22 42cb b17e 3f424cbca6b0)
Version | 1.1 |
Category | EBM Modules |
Colour Sensor component
This board provides the ability to detect colours using the TCS3200 sensor. It will return RGB and W values, dependent on the colour of the object under test.
Please click here to download the component source project: FC_Comp_Source_EBM018v2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM018v2.fcfx
Sample program using the EBM018 - Colour sensor
Sets filter to RGB and W and reads values,displays on LCD
GetFrequency
GetFrequency |
Samples and returns the sensor output frequency (Hz) | |
Return |
Initialise |
Initialise the sensor configuration as set by the component properties | |
Return |
SetConfig
SetConfig |
Sends the config data byte to the sensor using clock and data pins | |
Data |
Return |
SetFilter
SetFilter |
Dynamically change the sensor filter to RGB or W. Red = 0 Green = 1 Blue = 2 White = 3 | |
FilterColour |
Filter Colour; Red = 0, Green = 1, Blue = 2 and White = 3 | |
Return |
SetFrequencyRange
SetFrequencyRange |
Dynamically change the sensor output frequency range to a new setting | |
Freq |
Percentage range (2,20,100) | |
Return |
SetLEDOff
SetLEDOff |
Turn off the White LEDs | |
Return |
SetLEDOn
SetLEDOn |
Turn on the White LEDs | |
Return |
