Component: Accel / Gyro 6-Axis (MPU-6050) (Movement Orientation)
Version 2.1
Category Movement Orientation
Accel / Gyro 6-Axis (MPU-6050) component
MPU-6050 Combined 6-Axis Accelerometer and Gyroscope sensors. Useful for working out data such as Pitch and Roll. Can be combined with a Magnetometer to also provide Yaw.
GetAccelReading
GetAccelReading
Collects one of the accelerometer readings from the last sample.
- BYTE Axis
0=X, 1=Y, 2=Z
- INT Return
GetAccelReadingReal
GetAccelReadingReal
Collects one of the accelerometer readings from the last sample in G.
- BYTE Axis
0=X, 1=Y, 2=Z
- FLOAT Return
GetGyroReadingReal
GetGyroReadingReal
Collects one of the gyroscope readings from the last sample in degrees/s.
- BYTE Axis
0=X, 1=Y, 2=Z
- FLOAT Return
GetGyroReadng
GetGyroReadng
Collects one of the gyroscope readings from the last sample.
- BYTE Axis
0=X, 1=Y, 2=Z
- INT Return
GetTempReadingInt
GetTempReadingInt
Collects the temperature reading in degrees C as an integer value.
- INT Return
GetTempReadingReal
GetTempReadingReal
Collects the temperature reading in degrees C as a floating point value.
- FLOAT Return
Startup the I2C bus and configure the device. Returns 0 if the device is ok and 255 if the device is not responding correctly.
ReadRegister
ReadRegister
Reads the value from one of the registers onboard the device.
- BYTE Address
SampleDevice
SampleDevice
Collects the accelerometer, gyro and temperature readings from the device,
WriteRegister
WriteRegister
Sets the value of one of the registers on the device.
- BYTE Address
- BYTE Value
Device Specific
Address Bit AD0
Gyro Range
Accel Range
Channel selection
Baud Select
Baud rate to be used
SDA
SCL
Stop Delay
Simulate Comms
Please click here to download the component source project: FC_Comp_Source_MPU-6050.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MPU-6050.fcfx
