Component: Raspberry Pi HDMI (Graphical Color)
Author MatrixTSL
Version 1.4
Category Graphical Color
Raspberry Pi HDMI component
Graphical display component designed to work with the HDMI screen output of the Raspberry Pi
Version information
BPlot
Fc9-comp-macro.png BPlot
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
ClearDisplay
DebugState
Fc9-comp-macro.png DebugState
Set debug console print on or off
Fc9-u8-icon.png - BYTE State
Debug on if non-zero
DrawArc
Fc9-comp-macro.png DrawArc
Draws an arc either as an outline or as a filled object.
Center X coordinate
Center Y coordinate
Radius, distance of edge from the centre coordinates
Fc9-f32-icon.png - FLOAT StartAngle
Angle to start drawing, in degrees
Fc9-f32-icon.png - FLOAT EndAngle
Angle to end drawing, in degrees
Fc9-u16-icon.png - UINT Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
Fc9-u8-icon.png - BYTE Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
Fc9-comp-macro.png DrawCircle
DrawEllipse
DrawLine
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
DrawRectangle
Fc9-comp-macro.png DrawRoundedRectangle
Draws a rectangle with rounded corners
FastPlot
Fc9-comp-macro.png FastPlot
GetTouchCoordinates
Fc9-comp-macro.png GetTouchCoordinates
Reads the value of the last touchscreen input from the display. Returns a 0 if no new touch is detected. Otherwise returns flags for switches pressed
Fc9-comp-macro.png Initialise
Plot
Fc9-comp-macro.png Plot
Print
Fc9-comp-macro.png Print
Fc9-u8-icon.png - BYTE Font
Fc9-s16-icon.png - INT Number
ReadFontStat
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
ReadFontWidth
ReadTouchCoordinates
Fc9-comp-macro.png ReadTouchCoordinates
Returns the coordinates of the last touch event. Axis = 0 or 'x' or 'X' - Returns the X coordinate. Axis = 1 or 'y' or 'Y' - Returns the Y coordinate.
Fc9-u8-icon.png - BYTE Axis
ReadTouchData
Fc9-comp-macro.png ReadTouchData
Returns the raw data from the last get touch/mouse event. Use Index to return a data element from the array, Data[0] = flags Data[1] = delta x Data[2] = delta y
Index of the data to return from the array
Fc9-s16-icon.png - INT Return
SetBackgroundColour
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
SetDisplayOrientation
SetFontScaler
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
SetForegroundColour
Uninitialise
Fc9-comp-macro.png Uninitialise
Window
Fc9-comp-macro.png Window
Fc9-conn-icon.png Dimensions
Fc9-conn-icon.png Colour
Fc9-conn-icon.png Bit Depth
Fc9-type-14-icon.png Colour Bit Depth
Fc9-conn-icon.png Fonts
Fc9-conn-icon.png Font 0
Fc9-type-21-icon.png Bytes Required
Number of bytes required in program memory to store the selected font.
Fc9-type-21-icon.png Character Spacing
Sets the number of blank pixels between each character when printing text.
Fc9-type-21-icon.png Space Width
Fc9-conn-icon.png Simulation Mode
Fc9-type-16-icon.png Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_RPi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_RPi.fcfx
