| Author
Matrix Ltd
| Version
1.2
| Category
Comms: Interface
LIN Slave component
Low level routines for controlling the LIN bus (1.3 / 2.0) slave interface.
Please click here to download the component source project: FC_Comp_Source_LinSlaveV2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LinSlaveV2.fcfx
| Initialises the device ready for communications from the master. Puts the bus into the Wake state driving the CS pin high.
ListenForMessages
| Listens for messages with Timeout and returns the state. Returns 255 for timeout, 254 for CRC error and 0 for none matching ID received. Returns 1-8 for a valid ID received.
- BYTE
Timeout
| timeout in milliseconds to wait for incoming message, 255=Wait Forever
- BYTE
PowerDown
PowerDown
| Puts the bus into the Powered Down state driving the CS pin low.
ReadData
ReadData
| Get the Message data automatically received from a specific message as part of the ListenForMessages macro.
- BYTE
Message
| Message index to be read. Range: 1 - Num Messages
- BYTE
Data
- BYTE
ReadDataCount
ReadDataCount
| Return the data count size for Message
- BYTE
Message
- BYTE
SetData
SetData
| Set the Message data to be automatically sent for a specific message as part of the ListenForMessages macro.
- BYTE
Message
| Message index to write. Range: 1 - Num Messages
- BYTE
Data
- BYTE
WakeUp
WakeUp
Bus Options
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
| Baud rate option selector
Messages
| Number of messages the firmware is designed to listen for
Checksum Type
TX
| Pin to be used for Transmit data
RX
| Pin to be used for Receive data
CS pin
| LIN bus chip select pin
MESSAGE1
ID
| Message identifier to listen for
BYTES
| Number of bytes to expent in the packet
TX_RX
| Data direction for packet
| Selects if the scope traces are automatically added to the data recorder window or not. Simulation - draws an approximation of the UART data onto the scope trace. ICT - sets up the scope trace for incoming data and adds UART packet decoding at the correct BAUD.
Console Format
| Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
