Component: LED (EB004) (E-blocks 1)
| Version | 1.1 |
| Category | E-blocks 1 |
LED component
An LED matrix made up of standard PCB mount 5mm LEDs.
Please click here to download the component source project: FC_Comp_Source_LED_Array_EB004.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Array_EB004.fcfx
AllOff
| AllOff | |
| Turns off all elements | |
AllOn
| AllOn | |
| Turns on all elements | |
BarGraph
| BarGraph | |
| Turns on the first N elements of the array - for generating bar graph metes etc. | |
| Length | |
| How many items to light up. | |
LEDOff
| LEDOff | |
| Turn off the selected led. | |
| Index | |
| Index of the LED to turn on. | |
LEDOn
| LEDOn | |
| Turn on the selected LED. | |
| Index | |
PointGraph
| PointGraph | |
| Turns on the Indexed LED and turns all others off. Does nothing if the index is out of range. | |
| Index | |
| The LED to show. | |
WriteValue
| WriteValue | |
| Write a number which is presented on the LEDs in binary. | |
| Value | |
| Provide a value to be written to the LEDs in binary | |
| Properties | |
| Connections | |
| Output Mode | |
| Choose a single port for all LEDs, or to allocate them to arbitrary pins. | |
| Port | |
