Component: Bluetooth (ESP32 SPP) (Wireless)
| Category | Wireless |
Bluetooth (ESP32 SPP) component
Bluetooth slave component designed to run on a ESP32 providing legacy SPP functionality. BT Legacy functionality must be switched on via the sdkconfig file.
Please click here to download the component source project: FC_Comp_Source_Bluetooth_ESP32_SPP.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Bluetooth_ESP32_SPP.fcfx
A simple example file showing how to send and receive data using the ESP32 Bluetooth Serial Port Profile.
The SPP legacy bluetooth mode must be enabled in the ESP32 config file to allow SSP to work. For details please see this forum topic.
For problems sending strings or missing data bytes, please see this forum topic.
CheckConnectionStatus
| CheckConnectionStatus | |
| Checks to see if the Bluetooth device is connected. Returns 1 if connected. | |
| Starts up the Bluetooth communications SPP service. | |
ReceiveArray
ReceiveByte
| ReceiveByte | |
| Attempts to receive a byte from the bluetooth serial port. 0-255 = a valid received value 256 = a timeout has occured | |
| Timeout | |
| Number of ms to wait for incoming data | |
ReceiveCount
| ReceiveCount | |
| Collects the number of bytes currently stored in the receive buffer. | |
ReceiveINTArray
ReceiveString
| ReceiveString | |
| MaxBytes | |
| Max number of bytes to try and read within the time | |
| Timeout | |
SendArray
| SendArray | |
| Sends a byte to the Bluetooth serial connection | |
| Data | |
| Data Array to send | |
| NumBytes | |
| Number of bytes to send | |
SendByte
| SendByte | |
| Data | |
SendINTArray
SendString
| SendString | |
| Sends a string to the Bluetooth serial connection | |
| Data | |
SetBTName
| SetBTName | |
| Overrides the current friendly name | |
| Name | |
| Name you want to use | |
Uninitialise
| Uninitialise | |
| Shots down the Bluetooth communications SPP service. | |
