Component: TTI Power Supply - PL155-P (TTI PL155-P PSU) (Test Equipment)
(Redirected from Component: ID 8c08bf29 be7e 4408 92bc 91c476fb70db)
| Category | Test Equipment |
TTI Power Supply - PL155-P component
TTI PL155-P Power Supply Unit Component. 15V - 5A
Please click here to download the component source project: FC_Comp_Source_TTIPL155PPSU.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_TTIPL155PPSU.fcsx
ADDRESSRet
| ADDRESSRet | |
| Returns the bus address of the instrument; This is the address used by the GPIB, if fitted, or may be used as a general identifier over the other interfaces. | |
CLS
| CLS | |
| Clear Status. Clears the Status structure. This indirectly clears the Status Byte Register. | |
CONFIGRet
DAMPING
DECI
| DECI | |
| Decrement the output <n> current limit by the step size set for output <n>. | |
| Output | |
| Choose Output: 1 = Output 1, 2 = Output 2 (if applicable) | |
DECV
| DECV | |
| Decrement the output <n> voltage by the step size set for output <n>. | |
| Output | |
DECVV
| DECVV | |
| Decrement the output <n> voltage by the step size for output <n> and verify. | |
| Output | |
DELTAI
DELTAIRet
| DELTAIRet | |
| Returns the output <n> current step size. The response is DELTAI<n><nr2><rmt> where <nr2> is in Amps. | |
| Output | |
DELTAV
| DELTAV | |
| Set the output <n>voltage step size to <nrf> Volts | |
| Output | |
| Voltage | |
| Set a Voltage step between 0.0 - 15.0 V | |
DELTAVRet
| DELTAVRet | |
| Returns the output <n> voltage step size. The response is DELTAV<n><nr2><rmt> where <nr2> is in Volts. | |
| Output | |
EERRet
| EERRet | |
| Query and clear Execution Error Register. The response format is nr1 <rmt>. | |
ESE
| ESE | |
| Sets the Standard Event Status Register to the value of <nrf>. | |
| Status | |
| Set status register to a value of 0-255 | |
ESERet
| ESERet | |
| Returns the value in the Standard Event Status Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>. | |
ESRRet
| ESRRet | |
| Returns the value in the Standard Event Status Register in <nr1> numeric format. The register is then cleared. The response is <nr1><rmt>. | |
I
| I | |
| Set output <n> current limit to <nrf> Amps | |
| Output | |
| Current | |
| Set a current between 0 - 5000 mA | |
IDNRet
| IDNRet | |
| Returns the instrument identification. The exact response is determined by the instrument configuration and is of the form <NAME>, <model>, <Serial No.>, <Version>, <rmt>. | |
IFLOCK
IFLOCKRet
IFUNLOCK
INCI
| INCI | |
| Increment the output <n> current limit by the step size set for output <n>. | |
| Output | |
INCV
| INCV | |
| Increment the output <n> voltage by the step size set for output <n>. | |
| Output | |
INCVV
| INCVV | |
| Increment the output <n> voltage by the step size for output <n> and verify. | |
| Output | |
IORet
| IORet | |
| Returns the output readback current for output <n> The response is <nr2>A<rmt> where <nr2> is in Amps. | |
| Output | |
IRANGE
IRANGERet
IRet
| IRet | |
| Returns the set current limit of output <n> The response is I <n><nr2><rmt> where <nr2> is in Amps | |
| Output | |
ISTRet
| ISTRet | |
| Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true. | |
LOCAL
| LOCAL | |
| Go to local. This does not release any active interface lock so that the lock remains with the selected interface when the next remote command is received. | |
LSE
| LSE | |
| Set the value of LSE <n>, Limit Event Status Register <n>, to <nrf>. | |
| Register | |
| Select Register | |
| Value | |
| Value to be placed in the register (0-255) | |
LSERet
| LSERet | |
| Return the value of LSE<n>, Limit Status Enable Register <n> - response is <nr1><rmt>. | |
| Register | |
| Select register | |
LSRRet
| LSRRet | |
| Query and clear Limit Event Status Register <n>. The response is <nr1><rmt>. See status reporting section for details. | |
| Register | |
| Select Register number | |
NOLANOK
| NOLANOK | |
| Disables the LAn Err message for no LAN connection found at power on if <nrf> is 1 and enables the message if <nrf> is 0. | |
| Status | |
| 0 = Message disabled, 1 = Message enabled | |
OCP
OCPRet
| OCPRet | |
| Returns the current trip setting for output <n> The response is CP<n><nr2><rmt> where <nr2> is in Amps. | |
| Output | |
OP
| OP | |
| Sets the output <n> on/off where <nrf> has the following meaning: 0=OFF, 1=ON. | |
| Output | |
| Status | |
| 0=OFF, 1=ON | |
OPALL
OPC
OPCRet
| OPCRet | |
| Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential. | |
OPRet
| OPRet | |
| Returns output <n> on/off status The response is <nr1><rmt> where 1 = ON, 0 = OFF. | |
| Output | |
OVP
OVPRet
| OVPRet | |
| Returns the voltage trip setting for output <n>. The response is VP<n>Mnr2><rmt> where <nr2> is in Volts. | |
| Output | |
PRE
| PRE | |
| Sets the Parallel Port Enable Register to the value <nrf>. | |
| Status | |
| Set register value 0-255 | |
PRERet
| PRERet | |
| Returns the value in the Parallel Poll Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>. | |
PSUInitialise
| PSUInitialise | |
| This macro is required to initialise the PSU | |
QERRet
| QERRet | |
| Query and clear Query Error Register. The response format is nr1<rmt>. | |
RATIO
| RATIO | |
| Set the ratio of output 2 (slave) to output 1 (master) in tracking mode to <nrf>, where <nrf> is the ratio in percent (0 to 100). | |
| Ratio | |
| Ratio percentage (0-100) | |
RATIORet
| RATIORet | |
| Query the ratio of output 2 (slave) to putput 1 (master) in tracking mode. The response is <nrf>, where <nrf> is the ratio in percent (0 to 100). | |
RCL
RST
SAV
SRE
| SRE | |
| Set the Service Request Enable Register to <nrf>. | |
| Status | |
SRERet
| SRERet | |
| Returns the value of the Service Request Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt> | |
STBRet
| STBRet | |
| Returns the value of the Status Byte Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>. | |
TRG
| TRG | |
| The PSU has no trigger capability. The command is accepted but performs no action. | |
TRIPRST
| TRIPRST | |
| Attempt to clear all trip conditions. | |
TSTRet
| TSTRet | |
| The PSU has no self test capability and the response is always 0 <rmt>. | |
V
| V | |
| Set output <n> to <nrf> Volts | |
| Output | |
| Voltage | |
| Set a Voltage between 0.0 - 15.0 V | |
VORet
| VORet | |
| Returns the output readback voltage for output <n> The response is <nr2>V<rmt> where <nr2> is in Volts. | |
| Output | |
VRet
| VRet | |
| Returns the set voltage of output <n> The response is V <n> <nr2><rmt> wjere <nr2> is in Volts. | |
| Output | |
VV
| VV | |
| Set output <n> to <nrf> Volts with verify. | |
| Output | |
| Voltage | |
WAI
| WAI | |
| Wait for the Operation Complete true. As all commands are completely executed before the next is started this command takes no additional action. | |
