Author
Matrix Ltd
Version
1.0
Category
Graphical Color
GLCD (SSD1963) Parallel component
Graphical display component designed to work with the SSD1963 controller IC Based on the SSD1963 16-bit colour graphical controller IC.
Version information
Without Touchscreen
Example using a 4.3" TFT Display using the SSD1963 Graphical LCD Controller.
GLCD 4.3
Example using a 7" TFT Display using the SSD1963 Graphical LCD Controller.
GLCD 7
With Touchscreen
Example using the XPT2046 touchscreen driver IC with a 4.3" TFT Display using the SSD1963 Graphical LCD Controller.
GLCD 4.3 Touch
Example using the XPT2046 touchscreen driver IC with a 7" TFT Display using the SSD1963 Graphical LCD Controller.
GLCD 7 Touch
BPlot
BPlot
- UINT
X1
- UINT
Y1
BacklightOff
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BacklightOn
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
ClearDisplay
ClearDisplay
DrawArc
DrawArc
Draws an arc either as an outline or as a filled object.
- UINT
X
Center X coordinate
- UINT
Y
Center Y coordinate
- UINT
Radius
Radius, distance of edge from the centre coordinates
- FLOAT
StartAngle
Angle to start drawing, in degrees
- FLOAT
EndAngle
Angle to end drawing, in degrees
- UINT
Resolution
Number of lines to draw from the center to the outer edge, 0=Fill
- BYTE
Transparent
Chooses the transparency - 0 = Arc contains background colour, 1 = Arc contains previous pixel data.
- BYTE
Solid
Chooses to fill with colour - 0 = Arc transparency data, 1 = Arc contains foreground colour.
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Draws a rectangle with rounded corners
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
FastBPlot
FastBPlot
FastPlot
FastPlot
Plot
Plot
- UINT
X1
- UINT
Y1
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetBackgroundColour
SetBackgroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
SetDisplayOrientation
- BYTE
Orientation
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
SetForegroundColour
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
Window
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
DataMode
Configures how the displays data pins are connected. Port uses a single port byte allowing for high speed. Individual pins allow for any combination of pins allowing for flexibility.
Data[7:0]
Microcontroller port pins to use to pass 8-bit parrallel data to the graphical display
Write
Write pin connection
Read
Read pin connection
Register Select (RS)
Use CS
Controls if the backlight is controlled using an I/O pin or fixed to be always on by the circuitry.
Chip Select
Chip select pin connection
Use Reset
Reset
Reset pin connection
Use Backlight Pin
Display Properties
FlipX
Flips the horizontal axis
FlipY
Flips the vertical axis
TFT Colour Bits
Sets the colour depth of the display so the SSD1963 controller IC outputs the correct colour sequences.
OffsetX
Pixel offset on the x axis
OffsetY
Pixel offset on the y axis
Display Refresh Rate
PLL Multiplier
Controls the refresh rate of the display. Range 0 - 255
PLL Divider
Controls the refresh rate of the display. Range 0 - 15
Fonts
Font Count
Font 0
Font
Bytes Required
Number of bytes required in program memory to store the selected font.
Character Spacing
Sets the number of blank pixels between each character when printing text.
Space Width
Component Label
User Label Text
Text to display
Component Label Scale
Physical Orientation
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1963.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1963.fcfx
