Component: E-block Helper (E-blocks 1)
(Redirected from Component: ID a5320e5b 75c1 4e67 9ed4 e933f40efc9a)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.1 |
| Category | E-blocks 1 |
E-block Helper component
A purely cosmetic component to help simplify E-block connections without having to keep referring to the datasheets. Specify which E-block your using and the component will give you options for the patch settings and display the connections required.
Please click here to download the component source project: FC_Comp_Source_E-block_Helper.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_E-block_Helper.fcfx
Example of E-blocks helper component being used to determine connections.
