Component: File (ESP32 SDMode) (File)
(Redirected from Component: ID a61211f1 3718 4d37 b4a4 c6193646ccfd)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 9.9 |
| Category | File |
- 1 File (ESP32 SDMode) component
- 2 Version information
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 AppendByteArrayToFile
- 5.2 AppendByteToFile
- 5.3 AppendFloatArrayToFile
- 5.4 AppendINTArrayToFile
- 5.5 AppendLongArrayToFile
- 5.6 AppendStringToFile
- 5.7 CloseFile
- 5.8 CreateFile
- 5.9 DeleteFile
- 5.10 Initialise
- 5.11 MoveToNextFileSector
- 5.12 OpenFile
- 5.13 OpenFolder
- 5.14 ReadByteArrayFromFile
- 5.15 ReadByteFromFile
- 5.16 ReadByteFromIndex
- 5.17 ReadFileLength
- 5.18 ReadFileSize
- 5.19 ReadFloatArrayFromFile
- 5.20 ReadINTArrayFromFile
- 5.21 ReadLongArrayFromFile
- 5.22 ReadStringFromFile
- 5.23 SetFileIndex
- 5.24 Uninitialise
- 5.25 WriteByteToBuffer
- 5.26 WriteFileSector
- 6 Property reference
- 7 Component Source Code
File component allowing access to read and write files on an SD card using the ESP32 SD Mode IO allowing for high speed data transfer using 1-bit or 4-bit SD access.
Version information
Library Version, Component Version, Date, Author, Info 9, 9.0, 04-03-25, MW, Changed tooltips from Not implemented on the RPI to Not implemented on the ESP32
| AppendByteArrayToFile | |
| Data | |
| Length | |
AppendByteToFile
| AppendByteToFile | |
| Data | |
AppendStringToFile
| AppendStringToFile | |
| Data_String | |
CloseFile
| CloseFile | |
CreateFile
| CreateFile | |
| Filename | |
DeleteFile
| DeleteFile | |
| Filename | |
| Starts up the SD card interface and checks to see if a card is compatible. Returns: 0=OK, 255=No Card, 254=File System Fail | |
| MoveToNextFileSector | |
| Not implemented on the ESP32 | |
| ForceNextSector | |
OpenFile
OpenFolder
| OpenFolder | |
| Folder_Name | |
| ReadByteArrayFromFile | |
| Reads a binary byte array from the currently open file. Auto increments the position in the file. Returns the number of values read. | |
| Data | |
| Length | |
ReadByteFromFile
ReadByteFromIndex
| ReadByteFromIndex | |
| Reads a byte of data from the local sector buffer. Return = Data byte read from the local sector buffer. | |
| Address | |
ReadFileLength
| ReadFileLength | |
ReadFileSize
| ReadFileSize | |
| Reads the entire size of the current file in bytes. | |
ReadStringFromFile
SetFileIndex
| SetFileIndex | |
| File_Index | |
| Range: 0 to 4 | |
Uninitialise
| Uninitialise | |
| Terminates connection to the SD card, unmounts the SD card and disabled the SD peripheral. | |
WriteByteToBuffer
| WriteByteToBuffer | |
| Address | |
| Data | |
WriteFileSector
| WriteFileSector | |
Please click here to download the component source project: FC_Comp_Source_File_ESP32_SDMode.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_File_ESP32_SDMode.fcfx
