Component: CAN Bus BL0140 (E-blocks 2)
(Redirected from Component: ID af9061e8 7f2b 475e 844f 66ab76823d07)
Jump to navigationJump to search| Author | |
| Category | E-blocks 2 |
- 1 CAN_Bus_BL0140 component
- 2 Detailed description
- 3 Examples
- 4 Macro reference
- 4.1 ChangeRate
- 4.2 CheckRx
- 4.3 GetRxData
- 4.4 GetRxDataCount
- 4.5 GetRxIDHi
- 4.6 GetRxIDLo
- 4.7 GetRxIDSimple
- 4.8 GetRxIdent
- 4.9 Initialise
- 4.10 ReadSwitches
- 4.11 SendBuffer
- 4.12 SetRxFilter
- 4.13 SetRxFilterID
- 4.14 SetRxMask
- 4.15 SetRxMaskID
- 4.16 SetTxData
- 4.17 SetTxID
- 4.18 SetTxIDSimple
- 4.19 SetTxIdent
- 4.20 ShowLEDs
- 5 Property reference
- 6 Component Source Code
ChangeRate
| ChangeRate | |
| Simple attempt to alter the bus rate of the CAN. External CAN channels only, | |
| Rate | |
| Rate: 0-3 where 0=125, 1=250, 2=500, 3=1000 | |
CheckRx
| CheckRx | |
| Checks to see if any messages are available for 'Buffer' specified | |
| Buffer | |
| Send buffer: 0 to 1 | |
GetRxData
| GetRxData | |
| Returns last received message data byte at position Index. Buffer parameter is currently ignored | |
| Buffer | |
| Index | |
GetRxDataCount
| GetRxDataCount | |
| Returns last received message data length. Buffer parameter is currently ignored | |
| Buffer | |
GetRxIDHi
| GetRxIDHi | |
| Gets the Hi byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous, | |
| Buffer | |
| Receive Buffer. Range 0-1 | |
GetRxIDLo
| GetRxIDLo | |
| Gets the Lo byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous, | |
| Buffer | |
GetRxIDSimple
| GetRxIDSimple | |
| Gets the Rx ID as a Integer Standard ID only 0-2047. | |
| Buffer | |
GetRxIdent
| GetRxIdent | |
| Gets the Rx ID as a Integer Standard and Extended IDs. | |
| Buffer | |
| Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
ReadSwitches
| ReadSwitches | |
| Returns switch input states from the external MCP2515 device. 0 = No Switch Pressed, 1 = Switch 1 Pressed, 2 = Switch 2 Pressed, 3 = Both Pressed (External CAN only) | |
SendBuffer
| SendBuffer | |
| Transmits one of the transmit buffers which should have already been populated with an ID and data. | |
| Buffer | |
| Specifies which transmit buffer to send | |
SetRxFilter
SetRxFilterID
SetRxMask
SetRxMaskID
SetTxData
SetTxID
SetTxIDSimple
| SetTxIDSimple | |
| Set the Tx CAN ID as a generic number. Standard IDs only 0-2047. | |
| Buffer | |
| Transmit buffer to load. Range: 0-2 | |
| ID | |
| The ID value you wish to use. Range: 0-2047 | |
SetTxIdent
ShowLEDs
| ShowLEDs | |
| Set LED state (External CAN only) | |
| led1 | |
| Controls LED 1. Range: 0-1 | |
| led2 | |
| Controls LED 2. Range: 0-1 | |
Please click here to download the component source project: FC_Comp_Source_EBlocks2_CAN_Bus_BL0140_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_CAN_Bus_BL0140_2d.fcfx
