Component: Barometer (BMP280 / Grove 101020192) (101020192) (Environmental)
(Redirected from Component: ID b52758bf 4466 48c0 8054 33ee4b11e82b)
| Version | 8.0 |
| Category | Environmental |
Barometer (BMP280 / Grove 101020192) component
Barometric pressure sensor with a I2C bus interface. Pressure range 300 to 1100 hPa. Temperature range -40 to +85 ?C.
Version information
Library Version, Component Version, Date, Author, Info 7,7.0, 27-06-24, MW, Fixed ReadPressureFloatSim as Get and Read value was set to (2). 7,7.0, 27-06-24, MW, Removed all references to humidity as not present within BMP280. 8,8.0, 27-06-24, MW, Added Ev_initialise API, setting the pressure of the library sensor to an inital value of 300.
Altitude
| Altitude | |
| Calculates the altitude based on difference between actual pressure and the pressure at the sea level P0=1013.25 hPa. | |
Forced_Read
| Forced_Read | |
I2C_Read_Register
| I2C_Read_Register | |
| Reads a byte value from a register on the device | |
| Address | |
I2C_Write_Register
| I2C_Write_Register | |
| Writes a byte value to a register on the device | |
| Address | |
| Value | |
| Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected. | |
ReadPressureFloat
| ReadPressureFloat | |
| Reads the pressure as a floating point value in Bars. Calls the ReadPressureRaw function and then converts to a meaningful value. | |
ReadTemperatureFloat
Reset
| Reset | |
| Resets the device | |
Please click here to download the component source project: FC_Comp_Source_Barometer_Grove_BMP280.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Barometer_Grove_BMP280.fcfx
