Component: Keypad (BL0138) (BL0138) (E-blocks 2)
(Redirected from Component: ID b904b771 a7bc 47ec a1ea 9d4c77afccf2)
| Category | E-blocks 2 |
Keypad (BL0138) component
Keypad component to drive the E-blocks 2 BL0138 Keypad board. Provides twelve individual raster scanned switches.
Version information
Library Version, Component Version, Date, Author, Info 9, 1.0, 08-05-25, BR, Added autodetect port on Ev_PostInitialise 10, 1.0, 08-05-25, BR, Adjusted Pins and Port to use inherited base properties
GetAscii
| GetAscii | |
| Gets the ASCII value for the current keypress. If no key is pressed then the macro returns the value 255. | |
GetIndex
| GetIndex | |
| Gets the index value for the current keypress. If no key pressed then the macro returns the value 255. | |
GetNumber
| GetNumber | |
| Gets the numeric value for the current keypress. If no key pressed then the macro returns the value 255. | |
GetString
| GetString | |
| Gets the ASCII value for the current keypress and returns in the form of a string. If no key pressed then the macro returns a null string. | |
WaitPressed
| WaitPressed | |
| Blocking call that waits for one of the keys on the keypad to be pressed. The index of the key that was pressed is passed back to the user. | |
WaitReleased
| WaitReleased | |
| Blocking call that waits for the keys on the keypad to be released. If no key is pressed then the function will return immediatley. | |
| Properties | |
| Connections | |
| Output Mode | |
| Port | |
Please click here to download the component source project: FC_Comp_Source_EB_KeyPad_BL0138.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EB_KeyPad_BL0138.fcfx
