Component: J1939 Automotive Node (Comms: System)
(Redirected from Component: ID d04f4385 497d 4e46 a71d 2c0ccb4b0421)
| Version | 1.1 |
| Category | Comms: System |
- 1 J1939 Automotive Node component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ClearSPN
- 5.2 Get_Address
- 5.3 Get_Status
- 5.4 Initialise
- 5.5 Message_Data_Clear
- 5.6 Message_Data_Read_SPN
- 5.7 Message_Data_Set
- 5.8 Message_Data_Write_SPN
- 5.9 Process
- 5.10 RegisterSPN
- 5.11 Rx_Message_Check
- 5.12 Rx_Message_Data
- 5.13 Rx_Message_Source
- 5.14 Rx_Transfer_Check
- 5.15 Rx_Transfer_Data
- 5.16 Tx_Message_Send
- 5.17 Tx_Transfer_Send
- 6 Property reference
Allows an automotive J1939 network node to be created sat on top of CAN bus. Used in heavy duty vehicles it provides a base layer on which 1-16 bit signals or SPN can be assigned and passed between nodes. SPN are arranged into groups called PGN which each contain eight bytes of data.
Please click here to download the component source project: FC_Comp_Source_J1939.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_J1939.fcfx
ClearSPN
| ClearSPN | |
| Clears the list of registered SPN allowing new SPN to be registered. | |
Get_Address
| Get_Address | |
| Returns the device (ECU) actual address | |
Get_Status
| Get_Status | |
| Returns the system status. 0 = Ready. 1 = Waiting address claim | |
| Initialise the CAN network and J1939 protocol | |
| Preferred_Address | |
| Preferred Address (Requested Address) | |
Message_Data_Clear
| Message_Data_Clear | |
| Clear the CAN Data Buffer | |
| DataBuffer | |
| Message_Data_Read_SPN | |
| Read the SPN value from the CAN data buffer | |
| SPN | |
| DataBuffer | |
Message_Data_Set
| Message_Data_Set | |
| Set all data in CAN Data Buffer to given value. e.g. 0 or 0xFF | |
| DataBuffer | |
| Value | |
| Message_Data_Write_SPN | |
| Write the SPN value to the CAN data buffer | |
| SPN | |
| Value | |
| DataBuffer | |
Process
| Process | |
| Does the message processing. Call this often. | |
| TimeElapsed | |
| Time elapsed since last call, in mS. Can be zero for frequent calling. | |
RegisterSPN
Rx_Message_Check
| Rx_Message_Check | |
| If a data message has been received returns the PGN,otherwise 0 | |
Rx_Message_Data
| Rx_Message_Data | |
| Returns the DLC and data of the last received message | |
| DataBuffer | |
Rx_Message_Source
| Rx_Message_Source | |
| Returns the Source Address of the last received message | |
Rx_Transfer_Check
| Rx_Transfer_Check | |
| Check for incoming multipart data transfers. If received, returns the PGN else 0 | |
Rx_Transfer_Data
| Rx_Transfer_Data | |
| Returns the byte count and data of the transfer message data | |
| DataBuffer | |
| Buffer to receive copied data | |
| Size | |
| Size (byte count) of buffer | |
Tx_Message_Send
| Tx_Message_Send | |
| Send the prepared CAN message | |
| PGN | |
| DLC | |
| DataBuffer | |
Tx_Transfer_Send
