Component: LCD (EB005) (E-blocks 1)
(Redirected from Component: ID d29dda88 17de 4008 991a c881890d4c57)
Version | 1.1 |
Category | E-blocks 1 |
LCD component
LCD based on the unit used in the Matrix EB005 E-block
Please click here to download the component source project: FC_Comp_Source_LCD_EB005.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LCD_EB005.fcfx
Example of a typical LCD pinout.
For the LCDs to work with the Flowcode LCD component they need to be connected up in 4-bit data mode.
The 4 data signals actually go to the upper data nibble on the LCD as shown below.
A simple example that shows how to use some common functions.
Clear
Clear |
Clears the entire contents of the display. | |
Return |
ClearLine
Command
Cursor
PrintAscii
PrintAscii |
Takes the ascii value for a character and prints the character | |
character |
Holds an ascii value. | |
Return |
PrintFormattedNumber
PrintNumber |
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 | |
Number |
Enter the number or variable to print to the LCD | |
Return |
PrintString
PrintString |
Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro | |
Text |
Enter the text or variable to print to the LCD | |
Return |
RAMWrite
RawSend
RawSend |
Sends data to the LCD display | |
data |
The data byte to send to the LCD | |
type |
A boolean to indicate command type: true to write data, false to write a command | |
Return |
RemapCharacter
ScrollDisplay
ScrollDisplay |
Scrolls the display left or right by a number of given positions. | |
Position |
Holds the number of positions to shift the display | |
Direction |
0 = left, 1 = right | |
Return |
Start
Start |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
Return |
