Component: Thermocouple TypeK (EBM008) (EBM Modules)
Category EBM Modules
Thermocouple TypeK component
A component matchin the Matrix EBM008 thermocouple board. As well as an interface to a standard TypeK thermocouple, this also includes a thermistor that is used for cold junction compensation.
Please click here to download the component source project: FC_Comp_Source_EBM008v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM008v1.fcfx
GetNTCADCValue
GetNTCADCValue
Get the current Integer value for the Cold Junction thermistor's ADC channel.
- INT Return
GetNTCTemperature
GetNTCTemperature
Get the current temperature in Celcius for the cold junction thermistor.
- INT Return
GetTypeKADCValue
GetTypeKADCValue
Get the current Integer value for the thermocouple probe's ADC channel.
GetTypeKTemperature
GetTypeKTemperature
Get the thermocouple probe temperature with compensation for the cold junction temperature.
- INT Return
Set up the thermocouple sensor ready for use.
SetColdPoint
SetColdPoint
Set the current thermistor temperature as the reference point for cold junction compenation.
SetColdPointValue
SetColdPointValue
Set the cold junction compensation point using a previously read ADC value.
- UINT ADC_value
Integer ADC value.
SetNTCTemperature
SetNTCTemperature
For the simulated cold junction thermistor... Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
- FLOAT Temperature
Zero to one value - representing min-max of the sensor.
SetTypeKTemperature
SetTypeKTemperature
For the simulated Type K thermistor... Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
- FLOAT Temperature
Type K ADC Channel
Analog channel used for the Type K Thermocouple input
NTC ADC Channel
Analog channel used for the NTC Thermistor input
VDD
Operating Voltage of the hardware. ADC full scall is processor power rail
A text label to help you identify the component on the panel.
Type K Thermocouple
Max. Temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Min. Temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Scale divisions
Number of numbered divisions shown on the thermometer scale.
NTC Thermistor
Max. Temp.
Min. Temp.
Scale divisions
