| Author
Matrix TSL
| Version
1.0
| Category
Comms: Networking
TCP/IP (W5500) component
TCP/IP component designed to work with the W5500 device used on the ETH WIZ Click
HTTP Server
Simple example showing the W5500 component being used stand alone to create a web server.
W5500 Webserver
Network Comms
Here are some examples using the Network Communication component linked to the W5500 component.
NetworkComms W5500 Client
NetworkComms W5500 Webserver
CreateIPSocket
CreateIPSocket
| Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
- BYTE
| Specifies the communications channel 0-3
- BYTE
Protocol
| Specifies which IP protocol to use
- BYTE
Broadcast
| Allows broadcast type packets to be sent and received
- BYTE
CreateMACSocket
CreateMACSocket
| This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE
Promiscuous
| Receive everything (1) or just data bound for your MAC (0)
- BYTE
Broadcast
| Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE
Error
| Allowsmessages with errors to be accepted (1) or rejected (0)
- BYTE
CreateTCPSocket
CreateTCPSocket
| This macro creates a socket for sending and receiving TCP data.
- BYTE
- UINT
Src_Port
| Port Number
- BYTE
CreateUDPSocket
CreateUDPSocket
| This macro creates a socket for sending and receiving UDP data.
- BYTE
- UINT
Src_Port
| Port Number
- BYTE
GetSocketStatus
GetSocketStatus
| This returns the state of the requested channel's socket.
- BYTE
- BYTE
| Resets and initialises the W5500 IC. Sets up the gateway address, subnet mask, device IP address and device MAC address. This macro must be called before any other TCP_IP component macros. Returns 1 to indicate successful communication.
- BYTE
MIAC_Module_GetData
MIAC_Module_GetData
- BYTE
Index
- BYTE
MIAC_Module_Message
MIAC_Module_Message
- UINT
CAN_ID
- UINT
CMD_ID
- BYTE
MIAC_Module_PushData
- BYTE
Data
MIAC_Module_SetData
MIAC_Module_SetData
- BYTE
Count
- BYTE
D0
- BYTE
D1
- BYTE
D2
- BYTE
D3
- BYTE
D4
- BYTE
D5
RxDataAvailable
RxDataAvailable
| This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
- BYTE
- BYTE
RxDataSize
RxDataSize
| This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE
- UINT
RxFlushData
RxFlushData
| Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE
RxMatchMyIP
RxMatchMyIP
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE
- BYTE
RxMatchMyMAC
RxMatchMyMAC
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE
- BYTE
RxMatch_2_Bytes
RxMatch_2_Bytes
| This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
| Specifies the value of the first byte
- BYTE
Byte2
| Specifies the value of the second byte
- BYTE
RxMatch_4_Bytes
RxMatch_4_Bytes
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
| Specifies the value of the third byte
- BYTE
Byte4
| Specifies the value of the fourth byte
- BYTE
RxMatch_6_Bytes
RxMatch_6_Bytes
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
| Specifies the value of the fifth byte
- BYTE
Byte6
| Specifies the value of the sixth byte
- BYTE
RxReadArray
RxReadArray
| A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
Data
- UINT
Count
RxReadByte
RxReadByte
- BYTE
- BYTE
RxReadHeader
| Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE
- BYTE
Idx
| Specifies the byte index to return
- BYTE
RxReadString
RxReadString
| A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
Length
- STRING
RxSkipBytes
RxSkipBytes
| Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE
- BYTE
Count
| Specifies how many bytes to skip
SetDestination
SetDestination
| This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
- BYTE
- BYTE
Dst_IP0
| Specifies the first byte of an IP address
- BYTE
Dst_IP1
| Specifies the second byte of an IP address
- BYTE
Dst_IP2
| Specifies the third byte of an IP address
- BYTE
Dst_IP3
| Specifies the fourth byte of an IP address
- UINT
Dst_Port
| Destination Port
- BYTE
SetGateway
SetGateway
| This macro sets up the Internet E-Block's Gateway address. In most circumstances, this macro will not be required as the gateway address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
| First Byte of IP address
- BYTE
IP1
| Second Byte of IP address
- BYTE
IP2
| Third Byte of IP address
- BYTE
IP3
| Fourth Byte of IP address
SetMACAddress
SetMACAddress
| This macro sets up the Internet E-Block's MAC address. In most circumstances, this macro will not be required as the MAC address setting in the component property page will remain constant throughout your application.
- BYTE
MAC0
| First Byte of address
- BYTE
MAC1
| Second Byte of address
- BYTE
MAC2
| Third Byte of address
- BYTE
MAC3
| Fourth Byte of address
- BYTE
MAC4
- BYTE
MAC5
| Fifth Byte of address
SetMyIP
SetMyIP
| This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
SetSubnetMask
SetSubnetMask
| This macro sets up the Internet E-Block's Subnet Mask. In most circumstances, this macro will not be required as the subnet mask setting in the component property page will remain constant throughout your application.
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TCPClose
TCPClose
| When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
- BYTE
TCPConnect
TCPConnect
| This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- UINT
Dst_Port
| Destination Port
- BYTE
TCPListen
TCPListen
| This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
- BYTE
TxEnd
TxEnd
| Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE
TxSendArray
TxSendArray
| This macro fills the specified channel's transmit buffer with data.
- BYTE
- BYTE
Data
| Data byte to append to Tx buffer.
- UINT
Count
TxSendByte
TxSendByte
- BYTE
- BYTE
Data
TxSendMyIP
TxSendMyIP
| This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE
TxSendMyMAC
TxSendMyMAC
| This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE
TxSendString
TxSendString
| This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
- BYTE
- STRING
Data
- BYTE
Length
TxStart
TxStart
| This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
Sim Type
| Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / Injector - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
TCP Simulation
Network Interface
| List of network interfaces connected to the PC. Sets which interface we are communicating via.
DHCP
Please click here to download the component source project: FC_Comp_Source_TCPIP_W5500.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_W5500.fcfx
