Component: Switch Push Button (Switch)
Author | Matrix TSL |
Version | 20.0 |
Category | Switch |
Switch Push Button component
A simple digital push switch allowing latched and none latched operation. In embedded mode displays the connecting pin and pin status.
Version information
Library Version, Component Version, Date, Author, Info 15, 15.0, 30-07-24, MW, Fixed a bug to make sure switch starts in the off position 17, 17.0, 16-04-25, MW, Fixed a bug that made boundary height too large 17, 17.0, 16-04-25, MW, Fixed a bug where Pin x and y lables remained visisble when supposed to be hidden 17, 17.0, 16-04-25, MW, Fixed a bug when sim stopped Switch changed from on to off, but pin remained at VCC 18, 18.0, 01-05-25, MW, Adjusted pin and component labels and bounds to decrease overall bounds size 18, 18.0, 01-05-25, MW, Changed labels so don't interact and change switch state 19, 19.0, 01-05-25, BR, Added option to hide label 19, 19.0, 01-05-25, BR, Fixed SameAsHandle label to update on rename event 20, 0.0, 14-05-25, MW, Changed Switch properties, so it does not grey out
Switch
(5V / 11K) * 10K = 4.54545V
Note: if you want to use switch functions e.g. Active Low or debounce ,you must use the ReadState function and not use just an input.
ReadState
ReadState |
Reads the button state as 0 for released or 1 for pressed Performs debounce if required | |
Return |
SetState
SetState |
Sets the switch to be on or off. | |
State |
The new state of the switch (true=on, false=off) | |
Return |
WaitUntilHigh
WaitUntilHigh |
Waits until the switch is in state 'high' The interpretation of 'high' depends on the polarity | |
Return |
WaitUntilLow
WaitUntilLow |
Waits until the switch is in state 'low' The interpretation of 'high' depends on the polarity | |
Return |
Please click here to download the component source project: FC_Comp_Source_Switch_Push_Button_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Push_Button_2dgi.fcfx
