| Author
Jac Kersing
| Version
1.0
| Category
Comms: IoT/Cloud
LoRaWAN (Seeed WIO-E5) component
LoRaWAN Component for the Seeed WIO-E5 module.
LoraWAN Demo
Example LoRaWAN demo file.
LoRaWAN Demo
ChkConnected
ChkConnected
| Sends AT command and checks response to check the LoRa E5 module is connected to the controller.
- INT
FreeUart
FreeUart
| Release UART resources (to allow for sleeping on some microcontrollers)
GetDownlinkByte
GetDownlinkByte
| Get one byte from the received downlink message, returns -1 if no more bytes are available.
- INT
GetId
GetId
| Get the specified ID from the LoRaWAN module. Valid types are DevEUI, AppEUI and DevAddr
- STRING
type
- STRING
GetPort
GetPort
| Get the portnumber of the downlink message.
- BYTE
GotDownlink
GotDownlink
| Was a downlink received?
- BOOL
Initialize
Initialize
| Initialize the component. Should be called before any other function is used but after the component received a hardware reset. (Toggle of the reset pin)
Join
Join
| Execute a join command to have the module join the LoRaWAN network. Returns 1 on a successfull join, 0 if the join failed. Keep in mind there is no interaction with the LoRaWAN network if Join mode is ABP so it will always succeed if all parameters have been initialized correctly. In Join mode OTAA a join will fail if the module does not get a valid response from teh network which may occur if the DevEUI, AppEUI or AppKey are not correct or if there is no coverage at the location.
- BYTE
LowPowerSleep
LowPowerSleep
| Set low power sleep mode. Specify the number of seconds to sleep in the range 6-12959.
- INT
seconds
- BYTE
ReInitUart
ReInitUart
| Reclaim the UART after low power sleep of the CONTROLLER (not the LoRaWAN module).
SendMsg
SendMsg
| Send LoRaWAN message, the message should be an array of byte values. To conserve airtime no ASCII strings should be used.
- BYTE
msg
- BYTE
len
- BYTE
SendMsgConfirmed
SendMsgConfirmed
| Send a confirmed LoRaWAN message, the message should be an array of byte values. To conserve airtime no ASCII strings should be used. Use confirmed messages sparingly as transmitting gateways can normally receive 8 parallel messages but not 1 message while transmitting. So it kills scalebility of a LoRaWAN network!
- BYTE
msg
- BYTE
len
- BYTE
SetDr
SetDr
| Explicitly set DataRate of transmissions. Valid values depend on the region used please consult the LoRaWAN regional parameter document to find them.
- BYTE
dr
- BYTE
SetId
SetId
| Set an ID. Valid options are "AppEUI", "DevEUI" and "DevAddr". The value to use is an 16 HEX character long string for EUIs or a 8 HEX characters long string for DevAddr. Examples: AppEUI: "001122334455AABB" DevAddr: "001122AA"
- STRING
type
- STRING
value
- BYTE
SetJoinMode
SetJoinMode
| Set the join mode, valid options are MODE_OTAA or MODE_ABP.
- STRING
mode
- BYTE
SetKey
SetKey
| Set encryption key. Valid key types are: "APPKEY", "APPSKEY" and "NWKSKEY". For OTAA only APPKEY is required. For ABP both APPSKEY and NWKSKEY are required. The value shoud be a 32 HEX character string. Example value: "00112233445566778899AABBCCDDEEFF"
- STRING
type
- STRING
value
- BYTE
SetLowPower
SetLowPower
| Set the Low Power mode of the module. Low power can be off (false) or on (true)
- BOOL
on
SetPort
SetPort
| Set the port used for transmissions
- BYTE
port
- BYTE
SetRegion
SetRegion
| Set the LoRaWAN region to be used. For US915 the band (of 8 channels) to be used needs to be specified as well, the band is ignored for EU868 TTN uses band 1 in US915.
- STRING
region
- BYTE
band
- BYTE
LoRaWAN settings
Max Downlink Size
| Sets the number of byte elements inside the circular buffer.
| UART Channel selector Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Baud Options
| Baud rate option selector
TX
| Pin to be used for Transmit data
TX Remap Pin
| Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
RX
| Pin to be used for Receive data
RX Remap Pin
| Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Console Format
| Controls if the data is shown as a log with time and date stamps or just as raw data
Console Columns
| Number of characters that can be displayed on a single line of the console.
Data Source
| Simulation data source used to allow the component to connect to various remote devices Nothing - Simulation data is ignored COM port - Routes the communication data to and from a physical or virtual COM port API - Routes the communication data via a data injector component on the Panel.
API
| Selects which API component to route the communication data via. Add API components to the panel before they will be available in this list. API components are available from the Comms component category.
Please click here to download the component source project: FC_Comp_Source_lora-e5-component.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_lora-e5-component.fcfx
