Component: GSM (BL0131) (E-blocks 2)
(Redirected from Component: ID e735f6a0 13c3 4ca3 9084 bdd19e21b8f8)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Category | E-blocks 2 |
GSM (BL0131) component
Please click here to download the component source project: FC_Comp_Source_EBlocks2_GSM_BL0131_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_GSM_BL0131_2d.fcfx
AnswerIncomingCall
|   | AnswerIncomingCall |
| Answers the phone for an incoming type call. Returns 0 for success and 255 for failure. | |
|  - BYTE | Return |
CheckForIncoming
|   | CheckForIncoming |
| Checks to see if any incoming phone call or SMS message. 0 = Nothing, 1 = Text Received, 2 = Phone Ringing | |
|  - BYTE | Return |
CheckNetworkStatus
|   | CheckNetworkStatus |
| Returns the state of the GSM network. 0 = Not connected, 1 = connected, 255 = no reply from GSM. | |
|  - BYTE | Return |
DeleteAllMessages
|   | DeleteAllMessages |
| Removes all pending text messages from the GSM module. Returns 0 for success and 255 for fail. | |
|  - BYTE | Return |
DialNumber
|   | DialNumber |
| Performs a standard voice call by dialling the number specified. Returns 0 for call in progress and 255 for no response. | |
|  - STRING | Number |
|  - BYTE | Return |
GetTextNumber
|   | GetTextNumber |
| Collects the sender's phone number from an incoming text message. | |
|  - BYTE | NumBytes |
|  - STRING | Return |
GetTextString
|   | GetTextString |
| Collects the text message data from an incoming text message. | |
|  - BYTE | NumBytes |
|  - STRING | Return |
HangUpCall
|   | HangUpCall |
| Ends a voice based call. Returns 0 for success and 255 for failure. | |
|  - BYTE | Return |
|   | Initialise |
| Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail. | |
|  - BYTE | Return |
ReadString
|   | ReadString |
| Copies the data from the data string array to a local string variable | |
|  - BYTE | NumBytes |
|  - STRING | Return |
SendCommand
|   | SendCommand |
| Sends a command string to the GSM module. 0 = Command sent ok, 255 = No Reply | |
|  - STRING | Command |
|  - BYTE | SendCR |
|  - BYTE | Return |
SendScript
|   | SendScript |
| Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx. | |
|  - BYTE | idx |
|  - BYTE | Return |
SendString
|   | SendString |
| Sends a string to the GSM module. | |
|  - STRING | Text |
|  - VOID | Return |
SendTextMessage
|   | SendTextMessage |
| Sends the text message data specified to the number specified using the SMS protocol. Returns 0 for success and 255 for failure. | |
|  - STRING | Number |
|  - STRING | Message |
|  - BYTE | Return |
StringReceive
|   | StringReceive |
| Attempts to receive a string from the GSM modem. | |
|  - BYTE | Return |
