Component: MIAC NXT / ECU (MIAC Module)
(Redirected from Component: ID f9109442 8b0f 47d6 b563 d085588af222)
| Version | 1.1 |
| Category | MIAC Module |
- 1 MIAC NXT / ECU component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 DisplayClear
- 5.2 DisplayClearLine
- 5.3 DisplayCursor
- 5.4 DisplayGetCursorPosition
- 5.5 DisplayPixel
- 5.6 DisplayPrintASCII
- 5.7 DisplayPrintFloat
- 5.8 DisplayPrintFormattedNumber
- 5.9 DisplayPrintNumber
- 5.10 DisplayPrintString
- 5.11 Initialise
- 5.12 InputAnalogByte
- 5.13 InputAnalogInt
- 5.14 InputDigital
- 5.15 Print
- 5.16 ReadEEPROM
- 5.17 ReadKeypad
- 5.18 ReadTransistorOutputCurrent
- 5.19 ReadUSBConnected
- 5.20 RelayOutputState
- 5.21 TransistorOutputState
- 5.22 TransistorPWMDuty
- 5.23 TransistorPWMEnable
- 5.24 WriteEEPROM
- 6 Property reference
Component to drive the MIAC NXT / MIAC ECU range of hardware.
Please click here to download the component source project: FC_Comp_Source_MIAC_NXT_Component_Source.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_NXT_Component_Source.fcfx
DisplayClear
| DisplayClear | |
| Clears all text from the display | |
DisplayClearLine
| DisplayClearLine | |
| Clears a single line of text from the display | |
| Line | |
| Line to clear. Range 0 to CharacterHeight - 1 | |
DisplayCursor
| DisplayGetCursorPosition | |
| Gets the current pixel position of the cursor within the coordinate space | |
| Axis | |
| 0=X, 1=Y | |
DisplayPixel
| DisplayPixel | |
| Sets or clears a pixel at location X, Y. | |
| X1 | |
| Y1 | |
| State | |
| 0=Off / 1=On | |
DisplayPrintASCII
| DisplayPrintASCII | |
| Prints a single ASCII character to the display | |
| Character | |
| Holds an ASCII value e.g. 'A' | |
DisplayPrintFloat
| DisplayPrintFloat | |
| Prints a formatted floating point number to the display | |
| Number | |
| DecimalPoints | |
| Number of decimal points to display | |
DisplayPrintNumber
| DisplayPrintNumber | |
| Prints a number to the display as an ASCII string | |
| Number | |
| Enter the number or variable to print to the display | |
DisplayPrintString
| DisplayPrintString | |
| Prints a string of ASCII characters to the display | |
| Text | |
| Enter the text or variable to print to the display | |
| Starts up the MIAC IO and display. | |
InputAnalogByte
| InputAnalogByte | |
| Reads one of the input channels ( IN1 - IN8 ) as an analogue value with range 0-255 | |
| Channel | |
| Range: 1 - 8 | |
InputAnalogInt
| InputAnalogInt | |
| Reads one of the input channels ( IN1 - IN8 ) as an analogue value with range 0-4095 | |
| Channel | |
| Range: 1 - 8 | |
InputDigital
| InputDigital | |
| Reads one of the input channels ( IN1 - IN8 ) as a digital value with range 0-1 | |
| Channel | |
| Range: 1 - 8 | |
ReadEEPROM
| ReadEEPROM | |
| Read a single byte from the EEPROM. | |
| Address | |
ReadKeypad
ReadUSBConnected
| ReadUSBConnected | |
| Checks to see if there is an active USB cable connected to the MIAC. Returns 1 if there is a USB cable present, otherwise returns 0. | |
RelayOutputState
TransistorPWMDuty
TransistorPWMEnable
WriteEEPROM
| WriteEEPROM | |
| Write a single byte to a location in the EEPROM. | |
| Address | |
| Data | |
