Component: Indicator Gauge (Indicators)
Version 1.3
Category Indicators
Indicator Gauge component
Simulation only round gauge/dial for SCADA applications. The range of values displayed is easily adjusted.
Please click here to download the component source project: FC_Comp_Source_IndicatorGauge.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_IndicatorGauge.fcfx
GetValue
GetValue
Get the current scale value - this will be the most recent value set using "SetValue", or from the most recent mouse click if the component is in "Control" mode.
- FLOAT Return
SetRange
SetRange
Set the minimum and maximum values of the scale
- FLOAT Minimum
Minimum value for the scale
- FLOAT Maximum
Maximum value for the scale
SetValue
SetValue
Set the pointer to the given value on the scale. Returns the angle required to point at the given value.
- FLOAT Value
The value on the scale to move the pointer to.
- FLOAT Return
Range
Minimum
Minimum value that the meter will show (fully counter-clockwise)
Maximum
Maximum value that the meter will show (fully clockwsie)
Startup State
Sets the initial value when loading the project or when the runtime starts.
Default Value
The default value used on initialise or runtime start.
Title
Show Title
Decides if the component title is shown
Title Colour
Title Label Color
Title Text
Title Label Text
Title Scale
Controls the size of the title text on the panel, default 1.2
Title Offset
Distance above component center to draw the title
Show Label
Decides if a label is shown detailing current setting of the control knob.
Label Colour
Sets the label colour
Label Units
Adds a unit to the end of the label
Label Decimal Points
Number of decinal points to draw on the label
Label Scale
Sets the size of the label on the panel, default 1.0
Label Offset
Distance above component center to draw the label
Numeric Labels
Decimals
Number of decimal places to show on the number labels.
Text Size %
Height of the number label text.
Font
Font for the number labels.
Divisions
Set the number of major scale divisions - these will be given number value labels.
Subdivisions
Number of smaller scale divisions in between the numbered ones.
Scheme
BG Color
Colour for the meter background.
Positive Color
Colour for the number labels for greater than zero.
Negative Color
Colour for the number labels for value greater than zero.
Needle Color
