Component: Input Digital (DSP Inputs)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 1.2 |
| Category | DSP Inputs |
Input Digital component
Allows the values from a buffer to be assigned. Either a value at a time or from an array. The input signal would usually take the form of an ADC reading or raw data values.
Please click here to download the component source project: FC_Comp_Source_DSP_Input.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Input.fcfx
Here is a basic example demonstrating how to pass a value into the DSP chain.
The input value in the example uses an ADC reading but this can be taken from anything such as a reading from a CSV file on a SD card or a value passed by a sensor on a I2C bus etc.
AddByte
| AddByte | |
| Adds a single byte value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1. | |
| Data | |
AddByteArray
AddFloat
| AddFloat | |
| Adds a single float value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1. | |
| Data | |
AddFloatArray
AddInt
| AddInt | |
| Adds a single integer value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1. | |
| Data | |
AddIntArray
AddLong
| AddLong | |
| Adds a single long value to the current location in the specified buffer. Auto increments current location if output buffer size is greater than 1. | |
| Data | |
AddLongArray
| Properties | |
| Buffer Size | |
| Number of individual elements the buffer can store, default 1. | |
| Buffer Type | |
| Sets the buffer data type, data is automatically scaled to fit and make full use of the data type. | |
