Component: LED Free (5mm, PCB) ()
| Author | Matrix Ltd |
| Version | 1.1 |
| Category |
LED Free (5mm, PCB) component
An industry standard 5mm diameter LED. Any color may be chosen, and the leads trimmed to length.
Please click here to download the component source project: FC_Comp_Source_led_5mm_basic_free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_led_5mm_basic_free.fcfx
