Component: MIAC (Arduino Compatible) (MIAC (Arduino-Compatible)) (MIAC Module)
Version 1.2 (Release)
Category MIAC Module
Image MIAC (Arduino_Compatible) (MIAC (Arduino-Compatible)) component
MIAC - Matrix Industrial Automotive Controller (Arduino-Compatible)
RelayOFF
Turns off the requested relay given by parameter RelayID, values 1 to 4
BYTE RelayID
The relay to turn off. From 1 to 4.
InputANALOG_10Bit
BYTE InputID
The input to read. From 1 to 8.
INT
PrintString
Prints the given character string to the display at the current cursor position and moves the cursor position.
<- STRING Str
The string to send to the display.
This parameter may be returned back to the caller
GetKeypad
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255
This macro has no parameters
BYTE
DisplayStart
Initialise the display ready for use
Prints the given number to the display starting at the current cursor position and moves the cursor position.
INT n
PrintASCII
Prints the given character to the display at the current cursor position and increments the cursor position.
BYTE Char
ASCII code of the character to print.
DrawLine
Draws or clears a line from start at sx:sy to end at ex:ey
BYTE sx
Start column position
BYTE sy
Start row position
BYTE ex
End column position
BYTE ey
End row position
BYTE state
1=active pixel, 0=cleared pixel
PrintFormattedNumber
Will allow you to print a number up to 32-bits with signed or unsigned formatting.
Signed = -2147483648 to 2147483647
Unsigned = 0 to 4294967295
ULONG Number
BOOL Format
0=Signed, 1=Unsigned
DrawRect
Draws a rectangular box from x1,y1 to x2,y2
BYTE x1
BYTE y1
BYTE x2
BYTE y2
BYTE state
1=draw pixel, 0=clear pixel
DisplayClear
Clears the display to white space
RelayON
Turns on the requested relay given by parameter RelayID, values 1 to 4
BYTE RelayID
The relay to turn on from 1 to 4.
OutputOFF
Outputs a digital low state on the output requested by parameter TransID
(Outputs 1 to 4)
BYTE TransID
1 to 4 (Outputs A to D)
DrawPixel
Draws, or clears, a pixel at point x,y
BYTE px
BYTE py
BYTE state
state = 0 clears the pixel, else draws the pixel
DisplayCursor
Moves the display cursor to the given position.
If the cursor is set to the origin at x=0, y=0, then the next character sent to the display will appear in the top left corner.
BYTE x
Position of the cursor in characters from left to right.
BYTE y
The line to move the cursor to.
OutputON
Outputs a digital high state on the output requested by parameter TransID
(Outputs 1 to 4)
BYTE TransID
InputDIGITAL
Returns the digital state of the input requested by parameter InputID
(Inputs 1 to 8)
BYTE InputID
The input number from 1 to 8.
BYTE
DisplayLight
Turns the display backlight on or off
BYTE state
DrawGlyph
Draws a character glyph on the display at position px, py
BYTE glyph
The glyph ident number
BYTE px
pixel column relative to the drawing origin (top left)
BYTE py
pixel row relative to the drawing origin (top left)
BYTE mode
0=opaque/cleared background, 1=transparent background
InputANALOG
Returns the 8 bit value for the analogue input requested by parameter InputID
(Inputs 1 to 8)
BYTE InputID
The input to read from 1 to 8.
BYTE
Simulation macro reference
EvClick
This component does not contain any properties
