Component: Quadrature Encoder (EBM007) (EBM Modules)
| Category | EBM Modules |
Quadrature Encoder component
Provides a rotary encoder with dual digital outputs that provide rotation and direction information. When connected to two digital inputs of a microcontroller a “digital pot” can be implemented to convert to digital values.
Please click here to download the component source project: FC_Comp_Source_EBM007v2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM007v2.fcfx
This example scans the encoder for changes and displays a counter on the LCD based on the movement of the encoder.
CheckForChanges
| CheckForChanges | |
| Polling function to check changes Returns 1 for chaged, 0 for no change, 255 for error | |
Disable
| Disable | |
| Disables the use of the quad encoder Once this ist called, the read functions will return zeros until the next Enable() call | |
Enable
| Enable | |
| Enables the use of the quad encoder If this is not called, the read functions will return zeros | |
ReadCounter
| ReadCounter | |
| Reads the current dial counter This is a counter from -32768 to 32767 | |
ReadCounter32
| ReadCounter32 | |
| Reads the current dial counter as a 32-bit value This is a counter from -2147483648 to 2147483647 | |
ResetCounter
| ResetCounter | |
| Resets the current dial counter to zero | |
WriteCounter
| WriteCounter | |
| Sets the value of the internal count variable. Range: -32768 to 32767 | |
| Value | |
WriteCounter32
| WriteCounter32 | |
| Sets the value of the internal count variable. Range: -2147483648 to 2147483647 | |
| Value | |
