| Author
MatrixTSL
| Version
6.6
| Category
Wireless
SRF (WirelessThings) component
The SRF is designed for wireless transmission and reception of serial data in an easy to use surface mounted module. It has an on-board balun and chip antenna, which can be detached for applications where an external antenna is required.
Version information
ChangeHWBaud
ChangeHWBaud
| Changes the hardware UART baud rate allowing for dynamic speed changes.
- BYTE
NewBaud
| 0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200, 8=250000
ReceiveByteArray
ReceiveByteArray
| Receives an array of bytes and returns the number of bytes received.
- BYTE
Data
| Array to store the incoming data
- UINT
NumBytes
| Maximum number of bytes to try and receive
- BYTE
Timeout
| Max amount of time in ms to wait between bytes
- BYTE
ReceiveChar
ReceiveChar
- BYTE
Timeout
- INT
ReceiveFloat
ReceiveFloat
| Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
| Max time in ms to wait in between bytes
- BOOL
IgnoreData
| 0=Dont ignore any data, 1=Ignore any initial none numeric data
- FLOAT
ReceiveNumber
ReceiveNumber
| Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
- BOOL
IgnoreData
- LONG
ReceiveString
ReceiveString
| Send a string of data using the SRF Module
- BYTE
Timeout
- BYTE
NumBytes
- STRING
SRFInitialise
SRFInitialise
| Initialise the SRF Module. Activate device through 'enable' pin, and wake device to ensure it is not sleeping.
SendByteArray
SendByteArray
| Transmits an array of bytes via the UART peripheral
- BYTE
Data
| Data to transmit
- UINT
NumBytes
| Number of bytes to send from the array
SendChar
SendChar
- INT
Char
SendFloat
SendFloat
| Sends out a floating point number as an ASCII String from the UART interface.
- FLOAT
Number
SendNumber
SendNumber
| Sends out a number as an ASCII String from the UART interface.
- LONG
Number
SendString
SendString
- STRING
Data
Sleep
Sleep
| Sets the SRF module to sleep mode. (Includes a 10mS delay to allow any data to finish sending)
Wake
Wake
| Wake the SRF module. Includes a 10ms delay to allow radio to wake.
Sleep Mode (ATSM)
| Defines which sleep mode will be used when calling the Sleep component macro.
| Serial comms data rate specified in bits per second.
| Onboard UART peripheral to use to perform serial commands. Software mode available but not recommended for receive applications unless combined with a pin interrupt.
Use TX
| Selects if the Transmit pin is used by the component. Yes: The TX pin is active and used to transmit data for the UART. No: The TX pin is disabled and free to be used as general I/O.
TX
| Pin to be used for Transmit data
TX Remap Pin
| Allows the hardware transmit pin to be configured from a list of available pins based on your target device,
Use RX
| Selects if the Receive pin is used by the component. Yes: The RX pin is active and used to receive data for the UART. No: The RX pin is disabled and free to be used as general I/O.
RX
| Pin to be used for Receive data
RX Remap Pin
| Allows the hardware receive pin to be configured from a list of available pins based on your target device,
Sleep
Data Source
| Simulation data source used to allow the component to connect to COM port hardware or the the data API components.
COM Port
| Lists all the current available COM port hardware on your PC.
Please click here to download the component source project: FC_Comp_Source_SRF_Component_v2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SRF_Component_v2.fcfx
