Component: Servo Motor Controller (Mechatronics)
Version 8.8
Category Mechatronics
Servo Motor Controller component
Can control up to eight standard PWM driven servo's. Supports 8-bit and 16-bit movement resolutions. 'Servo Object' properties allow you to connect the controller to on-screen simulations using the "Servo Motor" component and its derivatives.
Version information
Example showing how to control three servos using AutoMoveToPosion, MoveTopposition & SetPosition component macros.
FC6 Icon.png Controlling Servos Example.fcfx
Example using BL0162 Servo controller for BL0055 Arduino Shield
Samples the Port D8-D13 (portB) switches and moves the servo motors based on the input states.
D8 increments motor 0, D9 decrements motor on channel 0.
D10 increments motor 1, D11 decrements motor on channel 1.
D12 increments motor 3, D13 decrements motor on channel 2.
Connections:
Servo Board Port D0-D2.
Switch Board Port D8 - D13
LCD A0 to A5 (PortC)
FC6 Icon.png BL0162 Servos Example for BL0055
AutoMoveToAngle
Fc9-comp-macro.png AutoMoveToAngle
Automatically moves towards the new angle at a fixed rate determined by the AutoMoveSpeed. AutoMove not currently supported by ESP32.
The channel to assign the new position. Range: 0-7
Fc9-u8-icon.png - BYTE Angle
Angle in degrees, Range 0 to calibration angle
AutoMoveToPosition
Fc9-comp-macro.png AutoMoveToPosition
Automatically moves towards the new position at a fixed rate determined by the AutoMoveSpeed.
Fc9-u8-icon.png - BYTE Position
Position to automatically move to. Range: 0-255
AutoMoveToPositionInt
Fc9-comp-macro.png AutoMoveToPositionInt
Automatically moves towards the new 16-bit position at a fixed rate determined by the AutoMoveSpeed.
Fc9-u16-icon.png - UINT Position
Position to automatically move to. Range: 0-65535
DisableServo
Fc9-comp-macro.png DisableServo
Disables a servo channel effectivly disabling the motor.
The channel to set the position for. First channel is zero.
EnableServo
Fc9-comp-macro.png EnableServo
Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
Fc9-comp-macro.png Initialise
Sets up the servo motor interrupts
IsAutoMoving
Fc9-comp-macro.png IsAutoMoving
Is the AutoMoveToPosition movement complete. Returns 1 if the servos are still moving. Returns 0 if all servo movement is complete.
IsServoAutoMoving
Fc9-comp-macro.png IsServoAutoMoving
Is the AutoMoveToPosition movement complete for a specific servo output. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete.
Servo Motor Output Range: 0-7
MoveToAngle
Fc9-comp-macro.png MoveToAngle
Moves a single step towards the new angle, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
MoveToPosition
Fc9-comp-macro.png MoveToPosition
Moves a single step towards the new position, the rate of movement is determined by how often the move to macro is called. Returns 1 if the position has been reached.
Target position to move towards. Range: 0-255
MoveToPositionInt
Fc9-comp-macro.png MoveToPositionInt
Target position to move towards. Range: 0-65535
SetAutoMoveSpeed
Fc9-comp-macro.png SetAutoMoveSpeed
Sets the speed of the auto move to position macro. Default speed is shown in the Servo_Period_Multiplier property.
Fc9-u8-icon.png - BYTE Speed
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
SetAutoMoveSpeedInt
Fc9-comp-macro.png SetAutoMoveSpeedInt
Fc9-u16-icon.png - UINT Speed
SetPosition
Fc9-comp-macro.png SetPosition
Moves directly to the specified position with no interpolation.
Position to jump to. Range: 0-255
SetPositionInt
Fc9-comp-macro.png SetPositionInt
Moves directly to the specified position with no interpolation. Uses a 16-bit position parameter to add extra precision.
Position to jump to. Range: 0-65535
SetTrim
Fc9-comp-macro.png SetTrim
Allows the level of trim for each servo channel to be adjusted progmatically.
Fc9-u8-icon.png - BYTE Trim
Legacy: 0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us or Smooth: 0-200
Fc9-type-16-icon.png Channels (1 - 8)
Set the number of servo's that you need to control. Value from 1 to 8.
Fc9-type-5-icon.png Channel 0
Pin on which to output PWM for the servo motor.
Fc9-type-5-icon.png Channel 1
Fc9-type-5-icon.png Channel 2
Fc9-type-5-icon.png Channel 3
Fc9-type-5-icon.png Channel 4
Fc9-type-5-icon.png Channel 5
Fc9-type-5-icon.png Channel 6
Fc9-type-5-icon.png Channel 7
Fc9-conn-icon.png Resources
Fc9-type-10-icon.png Peripherals
Lists the internal peripherals of the MCU used by the component. When the servo motor is initialised you will not be able to use the listed peripherals for other functionality.
Fc9-conn-icon.png Trim
Fc9-type-16-icon.png Trim Mode
Fc9-type-16-icon.png Trim 0
Trim the pulse width for this channel. Use this to trim the positioning of two servos so that similar input values will produce the same degree of movement.
Fc9-type-16-icon.png Trim 1
Fc9-type-16-icon.png Trim 2
Fc9-type-16-icon.png Trim 3
Fc9-type-16-icon.png Trim 4
Fc9-type-16-icon.png Trim 5
Fc9-type-16-icon.png Trim 6
Fc9-type-16-icon.png Trim 7
Fc9-conn-icon.png Pulse Width
Fc9-type-21-icon.png Minimum (us)
Shortest pulse width that will be used.
Fc9-type-21-icon.png Maximum (us)
Longest pulse width used for the PWM signals.
Fc9-type-21-icon.png Period Multiplier
Number of instructions for 1 / 256th of the positional accuracy. This sets the default movement speed to maintain legacy move speeds. Also sets the multiplication factor to convert from a byte 0-255 to a clocked position value.
Fc9-conn-icon.png Simulation
Fc9-type-17-icon.png Servo Object 0
Drag a servo motor component onto the System Panel, and then select it here, to create an on screen simulation of the way that your flowchart moves the servo's. Servo motors should be based on the 'Servo Motor Base' component, or use a custom component set to responf to 'User.Notify' events (ID = n/a, Data = Position (0-127)).
Fc9-type-17-icon.png Servo Object 1
Fc9-type-17-icon.png Servo Object 2
Fc9-type-17-icon.png Servo Object 3
Fc9-type-17-icon.png Servo Object 4
Fc9-type-17-icon.png Servo Object 5
Fc9-type-17-icon.png Servo Object 6
Fc9-type-17-icon.png Servo Object 7
Please click here to download the component source project: FC_Comp_Source_Servo_Controller.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Servo_Controller.fcfx
