Component: Temp / Humidity (SHT41 / BL0144) (Environmental)
Version | 1.0 |
Category | Environmental |
Temp / Humidity (SHT41 / BL0144) component
Humidity and temperature sensor using an SHT41 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
An example displaying real temperatures and humidity using floats,
Grove 101020212 (SHT31) Example
ChangePrecision
GetHumidityInt
GetHumidityInt |
returns the relative Humidity reading as an integer value | |
Return |
GetHumidityReal
GetHumidityReal |
returns the Humidity reading as a float value | |
Return |
GetTemperatureInt
GetTemperatureInt |
Return temperature reading as an integer value in degrees C | |
Return |
GetTemperatureReal
GetTemperatureReal |
Return temperature reading as a float value in degrees C | |
Return |
SetTemperatureScale
SetTemperatureScale |
Sets the temperature scale to celcius or farenheit Default: Celcius | |
Scale |
0=Celcius, 1=Farenheit | |
Return |
Please click here to download the component source project: FC_Comp_Source_Humidity_SHT41.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Humidity_SHT41.fcfx
