Component: Temperature (TMP117) (Environmental)
| Category | Environmental |
Temperature (TMP117) component
The TMP117 provides high accuracy temperature monitoring via a digital I2C interface.
A basic example which moves an object on the panel. When the object is in range of the sensor the sensor output goes high, otherwise the sensor output goes low.
PhotoTransistorDemo
| Sets up the I2C ready for operation and initialises the sensor with the default settings. Returns 1 if the device is correctly identified. | |
ReadRegister
| ReadRegister | |
| Address | |
ReadTemperature
| ReadTemperature | |
| Reads the temperature as a floating point value in Celcius. | |
ReadTemperatureF
| ReadTemperatureF | |
| Reads the temperature as a floating point value in Fahrenheit | |
SetMode
| SetMode | |
| Sets the mode of the sensor and therefore the amount of power consumed by the sensor. | |
| Mode | |
| 0=Shutdown, 3=Triggered, 7=Continuous | |
SetTemperatureOffset
| SetTemperatureOffset | |
| Allows an offset to be written to offset the output temperature | |
| Offset | |
| Temperature offset in degrees C | |
WriteRegister
| WriteRegister | |
| Address | |
| Value | |
Please click here to download the component source project: FC_Comp_Source_Temperature_TMP117.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Temperature_TMP117.fcfx
