Component: WLAN (EB069, WIZ610wi) (Misc)
Jump to navigationJump to search| Author | Matrix Ltd. |
| Version | 1.3 |
| Category | Misc |
- 1 WLAN (EB069, WIZ610wi) component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 CheckForPageRequests
- 5.2 ConnectToSSID
- 5.3 DisableCommandMode
- 5.4 EnableCommandMode
- 5.5 GetInValue
- 5.6 GetReply
- 5.7 Initialise
- 5.8 ReadConnectionStatus
- 5.9 ReceiveIncoming
- 5.10 SendCommand
- 5.11 SendString
- 5.12 Send_Embedded_HTML_Page1
- 5.13 Send_Embedded_HTML_Page2
- 5.14 Send_Embedded_HTML_Page3
- 5.15 Send_Embedded_HTML_Page4
- 5.16 SetOutValue
- 6 Property reference
Wireless LAN component designed to work with the WIZ610wi module from Wiznet. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the EB069 E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN.fcfx
|   | CheckForPageRequests |
| To be called periodically. Returns non-zero if a request has been processed | |
|  - BYTE | Return |
ConnectToSSID
|   | ConnectToSSID |
| Attempts to connect to the given SSID and Key values. Returns 0 if successful. | |
|  - STRING | SSID |
|  - STRING | Key |
|  - BYTE | Return |
DisableCommandMode
|   | DisableCommandMode |
| Exits command mode | |
|  - VOID | Return |
EnableCommandMode
|   | EnableCommandMode |
| Enables command mode. Must be called before commands are issued. | |
|  - VOID | Return |
GetInValue
|   | GetInValue |
| Returns the string value of a Request parameter | |
|  - BYTE | index |
| Index of the request paramter, starting at zero. | |
|  - STRING | Return |
GetReply
|   | GetReply |
| Returns the last received response to a command. 0 = OK 1 = FAIL_ERR 2 = STX_ERR 3 = CMD_ERR 4 = PARAM_ERR 5 = ETX_ERR 6 = SERIAL 255 = TOUT | |
|  - BYTE | Return |
|   | Initialise |
| Initialise the device with the property data. Returns 0 if successful | |
|  - BYTE | Return |
|   | ReadConnectionStatus |
| Checks the connection status. Returns 0 if not connected, 1 if connected. | |
|  - BYTE | Return |
ReceiveIncoming
|   | ReceiveIncoming |
| Returns the received data string | |
|  - STRING | Return |
SendCommand
|   | SendCommand |
| Sends the given command and returns the reply status. (See GetReply for return values) | |
|  - STRING | Command |
|  - BYTE | Return |
SendString
|   | SendString |
| Sends the given Text. Appends a CR/LF pair of characters it CrLf is true. | |
|  - STRING | Text |
|  - BYTE | CrLf |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page1 |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page2 |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page3 |
|  - VOID | Return |
|   | Send_Embedded_HTML_Page4 |
|  - VOID | Return |
SetOutValue
|   | SetOutValue |
| Set the value of an outbound substitution string | |
|  - BYTE | index |
|  - STRING | value |
|  - VOID | Return |
