Component: Waveform Generator (DSP Inputs)
Author | Matrix Ltd |
Version | 1.2 |
Category | DSP Inputs |
Waveform Generator component
A waveform generator component designed to plug into the DSP system component and allow several discreet waveforms to be generated. Functions available include: Sine, Cosine, Square, Pulse, Triangle, Sawtooth, Noise, Custom
Please click here to download the component source project: FC_Comp_Source_DSP_Wave_Gen.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_Wave_Gen.fcfx
Basic Sine Wave Generator
FreqGen The frequency is controlled by adjusting the potentiometer on the panel.
The frequency generator period is controlled using the Period Offset property and/or the SetOffset component macro. The Offset value is the LUT index multiplier so a offset of 3.0 will only read every 3 values of the waveform to provide 1/3 of the period and generate 3 x the frequency. As the waveform period is being reduced there is potential for the signal to start to become less defined and more stepped.
Multi Wave Signal Generator
Switch-able mode frequency generator example file generating different waveforms depending on the value on pins RB0 and RB1.
0 = Sine, 1 = Square, 2 = Triangle, 3 = SawTooth
The frequency is controlled by adjusting the potentiometer on the panel, the waveform is controlled by adjusting the switches on the panel.
Generate
GenerateArray
GetOffset
GetOffset | |
Gets the current phase of the wave as an index from 0 to Num Samples. | |
- UINT | Return |
ModifyFrequency
ModifyFrequency | |
Sets the frequency output rate by altering the period offset to a new value. | |
- FLOAT | OffsetRate |
0.2=F/5 0.5=F/2 1.0=F 1.5=F*1.5 2.0=F*2 | |
- VOID | Return |
ModifyPhaseOffset
SetOffset
SetOffset | |
Sets the current phase of the wave as an index from 0 to Num Samples. | |
- UINT | Offset |
Offset Index: 0 to Num Samples -1 | |
- VOID | Return |
