Component: Webserver (GENERIC - Flash / File) (Comms: Networking)
Author Matrix Ltd.
Version 1.7
Category Comms: Networking
Webserver (GENERIC - Flash / File) component
Webserver component designed to work with Network Comms abstraction layer. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Webpages can be embedded into ROM or can be pulled directly from a local file or a SD card via the File component. The File mode allows for images and other media to be served to the web client.
Webserver Embedded Files
A simple example demonstrating how to host a website with fixed HTTP content including dynamic sections that can be passed in and out of Flowcode SCADA.
For example a dynamic section could be used to display a variable value on a webpage such as a temperature or used to control Flowcode e.g. turn on an output.
FC6 Icon.png Webserver Embedded
Webserver Dynamic Files
Flowcode Embedded
A simple example demonstrating how to host a website with dynamic content based on external files including dynamic sections that can be passed in and out of an embedded system using an SD card and an ESP8266 module.
FC6 Icon.png ESP8266 Webserver FileSystem
ZIP Icon.png Webserver Files
Flowcode App Developer
A simple example demonstrating how to host a website with dynamic content based on external files including dynamic sections that can be passed in and out of Flowcode App Developer.
FC6 Icon.png Webserver FileSystem
CheckSocketActivity
Fc9-comp-macro.png CheckSocketActivity
Checks for activity on the server socket and serves out the webpages to any requesting parties. Returns: URL string request, or null string if no activity has occured.
CreateServerSocket
Fc9-comp-macro.png CreateServerSocket
Creates a listening socket on the selected port ready to accept incoming web page requests. Returns: 1 = OK / 0 = Listen Err / 255 = Socket Open Err
Fc9-u16-icon.png - UINT Port
Default HTTP port = 80
GetInValue
Fc9-comp-macro.png GetInValue
Fc9-u8-icon.png - BYTE Index
Incoming string Index Range: 0 to Incoming Count - 1
GetInValueFloat
Fc9-comp-macro.png GetInValueFloat
Returns the float value of an incoming Request parameter
Range: 0 to IncomingCount - 1
GetInValueLong
Fc9-comp-macro.png GetInValueLong
Returns the integer value of an incoming Request parameter
Fc9-comp-macro.png Initialise
Resets and initialises the Web Server component.
SetOutValue
Fc9-comp-macro.png SetOutValue
Incoming string Index Range: 0 to Outgoing Count - 1
Fc9-string-icon.png - STRING Value
SetOutValueFloat
Fc9-comp-macro.png SetOutValueFloat
Sets one of the outgoing substitution values from a floating point value.
Range: 0 to OutgoingCount - 1
Floating point value to assign to the substitution
Fc9-u8-icon.png - BYTE NumDP
Number of decimal points to add
SetOutValueLong
Fc9-comp-macro.png SetOutValueLong
Sets one of the outgoing substitution values from a numeric value.
Fc9-s32-icon.png - LONG Value
signed long integer value to assign to the substitution
Fc9-type-10-icon.png Label
Fc9-type-21-icon.png RX Buffer Size
Number of received bytes to buffer used to process URL and incoming parameters.
Fc9-type-21-icon.png Timeout
Number of milliseconds to wait when performing the CheckSocketActivity macro.
Fc9-type-16-icon.png LinkTo
Fc9-conn-icon.png Source Files
Fc9-type-16-icon.png HTML Source
Sets the method for streaming data, we can either host it loacally using a property or refer to external files.
Fc9-type-7-icon.png Customise Header
Fc9-type-7-icon.png Use Callback
If set to 'yes', a macro called 'HtmlCallback' with 4 parameters is required: * name - STRING[32] - the name of the web page * params - STRING[128] - a string of parameters sent to the webpage * idx - UINT - an increasing number * html - byref STRING[256] - the returned html to send The return type should be a BOOL and the macro should return true if this is the last callback iteration and the response is complete. This callback macro is repeatedly called with an increasing value of 'idx' when a page request is detected.
Fc9-conn-icon.png HTML Pages
Fc9-type-14-icon.png Max Pages
Maximum number of pages we can serve using the embedded page type webserver. Currently limited to 4 pages.
Fc9-type-10-icon.png Name Page 1
Name of HTML page 1 - index.htm is the default page that will be presented.
Fc9-type-11-icon.png HTML Page 1
Embedded HTML code used for page 1
Fc9-type-10-icon.png Name Page 2
Name of HTML page 2
Fc9-type-11-icon.png HTML Page 2
Embedded HTML code used for page 2
Fc9-conn-icon.png Substitutions
Fc9-conn-icon.png Outgoing
Fc9-type-16-icon.png Count
Fc9-type-21-icon.png Length 0
Fc9-conn-icon.png Incoming
Fc9-type-21-icon.png Length 1
Please click here to download the component source project: FC_Comp_Source_WebServer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WebServer.fcfx
