Hi all
I'm trying to figure out how the tcp/IP library works .
The set up I'm using is an Arduino nano and this wiznet5500 board ;
[https://pmdway.com/products/wiznet-w55 ... et-module]
I'm happy that i can ping to the board and it looks like the spi communication between the wiznet5500 board and nano works because of the feedback i get from the uart console .But i cannot send a message trough ethernet whatever i do .
kind regards ,Ruben
w5500[solved]
- Has thanked: 5 times
- Been thanked: 3 times
w5500[solved]
- ip.jpg (57.94 KiB) Viewed 2231 times
- UDP_NODE_A.fcfx
- (20.04 KiB) Downloaded 106 times
- kaart2_V1.fcfx
- (15.71 KiB) Downloaded 106 times
- Has thanked: 287 times
- Been thanked: 417 times
Re: w5500
Have you looked at the examples in the WiKi? They are a good starting point.
https://www.flowcode.co.uk/wiki/index.p ... etworking)
