ESP32 Toolchain.
Has thanked: 512 times
Been thanked: 472 times
ESP32 Toolchain.
Hi all.
As you may already be aware, Espressif Systems regally move the goal posts.
I have IDF 5.1.3 working as I had an issue with installing 5.1.0 (v5.1 release branch)
I was wondering what your experiences with installing either of the above versions.
For people that have not yet installed ESP32 tool chain, here are the ESP32 toolchain instructions.
Has thanked: 104 times
Been thanked: 511 times
Re: ESP32 Toolchain.
Post by mnfisher »
I had a bit of a play with 5.2 - but although I could compile from the command line couldn't get it to work from within FC.
So went back to 5.1.2. Which seems to work AOK..
MJU20
Has thanked: 75 times
Been thanked: 50 times
Post by MJU20 »
I recently went back to V4.3xx because of issues with V5.x.
The reason that most of my projects didn't compile "a-okay", was because of the Bluetooth that wasn't initialised.
With that knowledge, my projects compile ok at the moment.
I am hesitant to reinstall version 5 because of all the significant problems I've had with it in the past.
So could someone please reassure me that V5.x is better then V4x, and has more possibilities then V4. Or what other reason I should grab to upgrade to V5..x
