In your project options please can you turn off the Auto clear watchdog setting. The watchdog isn't running so these are a load of instructions that aren't required.
Also I would highly recommend disabling the Low Voltage Programming setting unless you are specifically using it. This can cause a stack of issues. e.g. freezing, self erase etc.
If these don't help then you could also try running the chip at a lower frequency and see if that resolves the problem. As a test maybe try 16MHz - OSCFRQ = 0x05; Remember to also update the frequency in the project options.
Modbus TCP Slave
- Has thanked: 445 times
- Been thanked: 605 times
Re: Modbus TCP Slave
