If you are running a version of Flowcode v10 prior to this new release, a notification of the core update will appear allowing it to be downloaded and installed. If you do not receive this notification and are using v10.1.0.38 or earlier, then please ensure you have "Check for core updates on launch" enabled in the Global Settings.
There have been some reports of problems when trying to install the core update. If this happens, then please restart your PC and run the update directly. It should be in "This PC...Downloads" and will be called "FlowcodeV10.1_QFE1-10.1.1.39.msp". Alternatively, the patch and the full download are available from the https://www.flowcode.co.uk/download/ download page.
These are the main changes since the previous release (v10.1.0.38) from last December:
- New Source control view with syntax colouring
- In-situ code editing now has accept/discard buttons, or prompts for confirmation when focus lost
- Indents are automatically maintained when editing code
- Separate syntax colouring of C code, JS code, macros, vars, etc.
- New Pseudocode view
- Different Pseudocode modes available
- New thinner Blocks view
- Customise each view type separately in Global Options
- Default macro view can be set (no longer fixed to flowchart)
- Fixed error display in calculations (etc)
- Added hover hints for variables, macros, etc, in calculations
- Fixed rubber-band selection within a macro
- You can now shift-select groups of icons to select a large block
- New <PostInitialise> event
- Variable name added to message when deleting in-use variables
- Document is marked as modified when panel name is changed
- Array size for variable is updated when editing a macro to/from a string return variable
- Added Set/GetComboIndex macros for ComboBox primitive
- Added Set/GetState macros for Button primitive
- Prevent interactive primitive macros from running when not simulating
- State Diagrams forbidden in Web Developer apps
- Fixed crash when ComplexShape data is illegal
- Draws a "!" when the ComplexShape data is illegal
Details for the previous updates can be found here:
