Button emulation relative to ports
Osta
Has thanked: 1 time
Been thanked: 3 times
Post by Osta »
Hey, everybody!
I have the task of putting buttons between the ports.
But in the emulator all the buttons work relative to ground,
Do you know if it is possible to simulate buttons in relation to ports?
Has thanked: 287 times
Been thanked: 417 times
Re: Button emulation relative to ports
Post by chipfryer27 »
Not sure if I understand your request correctly. Do you wish to connect a button for example between Port A0 and B0 or such like?
If so, how will the ports detect any change in voltage? Will you initially make Port A0 "high" and try and detect a "high" on Port B0? If so you could just set B0 to be "active high". Ports can be set to be active High or Low.
Sorry if I've misunderstood your request.
Osta
Has thanked: 1 time
Post by Osta »
I mean the dynamic polling of the buttons, as well as working with sensors that require polarity reversal and combined switching of other devices.
Has thanked: 446 times
Been thanked: 606 times
Possible yes, but you might need to create a component to allow you to do it, as you say the current built in components work to pull to the voltage rails VCC and VSS.
We can maybe help with creating a simple component but how would the switch work, i.e. when open would there be a pull to a third pin or to a voltage rail. when closed would there be a strong pull to a second pin or to a voltage rail?
The diagram here might help.
There is a weak pull when open and a strong pull when closed both would likely need to be defined. You could maybe get away from the need to use a third IO pin for the open (default) state if your MCU device has internal pull up and pull down resistors you can enable.
A simple schematic of what you are doing might help.
Osta
Has thanked: 1 time
Post by Osta »
Hi!!!
Sorry for the long silence - I was away.
This is for 8X8 keyboard. Moreover, the keyboard ports will switch to polling mode
at a certain time. The RX prot will be pulled up to the VSS by external resistors and the TX port
for the duration of the poll will go into the OUT state.
