I am using BL0011 programmer and trying to run the DC motor on the E-Blocks 2 board 0127. I need the motor to start forwards for 5 seconds and then stop for 5 seconds and then reverse. Whilst the simulation runs correctly to a degree it is returning an error when downloading to the micro. Can you please help. I have attached the file which is using flowcode 9.
Nev
Dc Motor start stop and reverse
- Has thanked: 516 times
- Been thanked: 474 times
Re: Dc Motor start stop and reverse
Your flowchart compiles for me OK, but the connections to the motor are wrong.
You will also need to select Full bridge if you want the motor to also go in reverse.
With the connections, the motor is connected to pins 1 and 2: You can determine the correct connections from the Eblocks2 datasheet.
I have attached an example just using a DC motor and the BL0127 Actuators Demo Flowcode9.
As for the error either Flowcode is not up-to-date or you have not got the required MECHATRONICS component pack, if the 30days trial has ended?
To update Flowcode, select Help, Library Updates...
Change the Files in-use to full database
If any components have been updated, you will need to select Reload for the effects to take place.
To see what pack you have installed, select Help, Licensing, View
Check that the Mechatronics has not got a red cross on it.
When you compile a flowchart, a file will be generated within the project folder ending in .msg.txt
E.g. Flowcode Motor.msg.txt
Can you attach the file so we can get a better idea of what is causing the flowchart compile failure?
you will need to Select Full Editor & Preview
- Flowcode Motor Example.fcfx
- (11.04 KiB) Downloaded 105 times
- BL0127 Actuators Demo Flowcode9.fcfx
- (25.66 KiB) Downloaded 88 times
I have updated files as you suggested and noted that the mechatronics pack does not have a red x. I have modified the motor to pins Port B1 and Port B2 the programme now compiles but the hardware i.e the motor does not respond. I have sent a photo of the set up in which the BL0127 board ic connected to port b and a copy of your modified file
- Motor Setup flowcode.docx
- (105.87 KiB) Downloaded 94 times
- (13.94 KiB) Downloaded 95 times
In the flowchart you posted, there are two motor components added.
I have deleted motor_full_bridge2 and compiled to my hardware and the motor on my actuators board is working as expected.
Can you make sure your hardware is being programmed and running OK by running a one-second flasher.
If the one-second flasher is working then can you take a picture of your hardware powered up?
Have you got a lead going from 5V of the BL0011 (or an external supply) to 5V-6V of the Actuators board?
If not, the motor won't run.
With power going to the board the Power LED should light.
Is the ON/OFF switch fully to the right?
Legend all sorted thank you very much for your time
Thanks again
Thanks again
