Hi!
I try to test the SK6812 RGBW component. When I added the component to the 2D or 3D dashboard panel it is not possible to se the led. If I with luck am able to click on the component on the dashboard I am able to see the properties and try to increase the size with and high nothing happend. What am I doing wrong please?
Br jorgen
SK6812
- Has thanked: 287 times
- Been thanked: 416 times
Re: SK6812
It appears to be a v9 bug. It works fine in v8.
I created a 1Dx 10 string in v8, saved and then opened in v9. I had to mess around with properties to get it displaying. Hopefully the attached will be of some use.
EDIT...
Had a further play. In v9 if you add the component then go to Project explorer and click on components, highlight the SK6812 and right-click-select the component will show in the panel, Well the positioning bars will. If you now go to the component properties and set Column Spacing to 1 then on mine at least you will see a string on the panel.
EDIT...
- Has thanked: 444 times
- Been thanked: 604 times
Re: SK6812
I think I've fixed it properly now so it should correctly appear when you drag it on.
I've also updated other similar components as they had similar issues.
