Hi Steve!
I can´t find:
(assuming you have "Check for core updates on launch" in Global setting, will you please help?
Br Jorgen
Flowcode v10 Flowcode v10.0.1.18
- Has thanked: 507 times
- Been thanked: 132 times
- Has thanked: 167 times
- Been thanked: 277 times
Re: Flowcode v10 Flowcode v10.0.1.18
Click the "File" menu and near the bottom is "Global Settings". The checkbox is in the "Application" tab, about half way down on the right.
Re: Flowcode v10 Flowcode v10.0.1.18 SOLVED!
Ok found it, but it should be active, but nothing happend when I open or saech for update?
***SOLVED Steve, Thank´s! *****
Jorgen
Jorgen
- core1.PNG (6.2 KiB) Viewed 681 times
- Has thanked: 285 times
- Been thanked: 412 times
With it checked, when you open FC next, a little message box should appear (lower right for me) informing that Core Updates are available.
HTH
HTH
