I have instaled the ESP v5.1.2 and it's working fine for the testprogram with an ESP32 C3.
that's really great!!
But for my old program with an ESP32 Pico I get a fail. I
I tested it before the update and it was working fine.
I also deleted all files and folders except the .fcfx file and recompiled it and it still failed.
ESP32 C3 working fine but problem "old" ESP32 Pico
- Has thanked: 150 times
- Been thanked: 171 times
- IMU_sdcard_Ch1.fcfx
- (129.1 KiB) Downloaded 64 times
- IMU_sdcard_Ch1.msg.txt
- (225.59 KiB) Downloaded 79 times
Re: ESP32 C3 working fine but problem "old" ESP32 Pico
I found two problem.
The first:
I have to remove watchdog C code so then a test-program is compiling. The second:
it's a little strange.
If I have a macro with a return type "Byte, Int, UInt...." it gives a fail
but if the return type is "string" then no fail...
A testprogram with fail if use ESP-IDF v5.1.2
The first:
- Has thanked: 444 times
- Been thanked: 604 times
Have you assigned a value to the return? I think the ESP compiler will error if there is a return that hasn't been assigned a value. For a string it's a pointer and so is probably less likely to moan about it not being populated as it's harder to know if it has been.
Yes I'm aware the watchdog timer fix code has stopped working, I need to look into this to find a new fix.
Yes, the ESP-IDF 5.12 need to assigned a value to the .return. (ESP-IDF 4 maybe not)
The testprogram 512_test_1.fcfx is working now.
I still have another fail to fix.
Is there an error message somewhere where the fails come from?
