Support for ADS1115 and ADS1118
- Has thanked: 2 times
- Been thanked: 3 times
Hello. I was thinking about using the ADS1115 and ADS1118 sensors, as they are very common and cheap. I saw an old post talking about the subject, but I saw that no components were created for the library. Has anyone managed to use these sensors using flowcode?
Re: Support for ADS1115 and ADS1118
Hello. Is there anything new? I'm curious to know if it worked haha
- Has thanked: 513 times
- Been thanked: 473 times
Just an update.
I have got the component to work with any channel in single end mode and you can set the gain.
currently there is only a raw and voltage option.
You can read raw with channel 1 at a gain of +/- 6.144V for example and also read volts with a different channel and a different gain as they are set in the functions rather than the properties.
I'm sorting out the simulation side, then I will post the component for you to try
It currently is limited to ADS1115, as that is all I have to hand.
Just an update.
I have attached the component to try.
The Gains that are within properties are for simulation only and not hardware.
The Gains parameters are included within the SampleSglRaw and SampleSglVolts Function macros.
Simulation should be working OK
Please take in go account the component is work in progress.
To try the component.
Place the attached component.
C:\ProgramData\MatrixTSL\FlowcodeV10\Components
- ADS111x.fcpx
- (8.07 KiB) Downloaded 8 times
