Hello, in Flowcode there is the RGBW SK6812 LED. Will there also be an RGB SK6812 variant?
Or can I also use it to control an LED (without a white LED)?
Thanks, regards Christian
SK6812 LED
- Been thanked: 1 time
Re: SK6812 LED
Suddenly I have a new additional problem: as soon as you select the SK6812 you get an error message when compiling, so even without having used any command.... Is there a bug in the program?
- Has thanked: 289 times
- Been thanked: 418 times
- Has thanked: 68 times
- Been thanked: 58 times
Re: SK6812 LED
It helps when you upload the flowchart you’re having issues with because it takes away a lot of guesswork. (Uploads are available in the full editor & preview mode you can open with the button below the text box)
Re: SK6812 LED
I'm sure that you are aware that FC doesn't support the PB variant but in saying that the PB will run code created for the P which FC does support. I'm sure you are also aware of the pin / functionality differences too.
I created a blank chart based on the ATMEGA328P with everything in config as default, then added in the SK6812 component, which has as default connectivity on Port C.5 and added a macro to initialise. Nothing else just what's mentioned.
This compiled successfully to C, and although throwing up a couple of warnings successfully compiled to Hex too. I can't try it with hardware though.
Is your library up to date?
Re: SK6812 LED
Yes, I know the differences to the P.
That's funny, until a few days ago it worked for me without an error message. I only started having these problems today.
I'll see if there could be another cause of the error.
Thanks for the help!
Best regards Christian
Re: SK6812 LED
Even if I create a new project and only select the SK6812 without any code, the error occurs when compiling.
In file included from C:\Users\Admin\Desktop\Flowprojekte\Testen.c:47:0:
C:\ProgramData\MatrixTSL\FlowcodeV9\CAL\ESP\ESP_CAL_RMT.c:112:19: error: conflicting types for 'FC_CAL_RMT_TX_1'
CALFUNCTION(void, FC_CAL_RMT_TX_, (void))
What could be the problem?
Greetings Christian
Greetings Christian
- Has thanked: 106 times
- Been thanked: 517 times
Re: SK6812 LED
This is an issue with ESP32 and later versions of the RMT interface.
See the post at viewtopic.php?p=14339#p14339
For a working version - the RMT interface and to have changed dramatically...
